Problem syncing contacts after CCC retrofit '05
Hi guys,
Few days ago I successfully retrofitted the CCC module in my car, which came with the Business Navigation.
The VO has been changed (added $609 option and removed $606). I haven't changed the VIN on the 5 CCC modules, yet but I doubt this is the problem. The CCC unit has a manufactured date 05.10.2005 and it is updated until DATEN V45, only the MOSTGW has a newer version which I'm not sure I will update, but I just might, if I start changing the VIN.
...so lets get to the problem...
Before the retrofit my iPhone 5 was successfully syncing contacts with the MASK unit. After the retrofit I deleted the phone and paired it again but the phone book remains empty. Some times it is saying 'PLEASE WAIT' and after several minutes (may be more than 5) it says 'NO ENTRIES'.
What could be the problem? Are the concats stored in the MULF (bluetooth module) or they are stored in the CCC unit, previuosly the MASK unit?
P.S. If someone calls me it displays his/hers name.
DavaiLave
08-02-2022 02:16 AM
