Just Activated Blue Tooth
Old Nov 18, 2004 | 08:07 AM
  #41
wassy's Avatar
Originally Posted by roost' date='Nov 18 2004, 10:54 AM
I noticed that my battery drained faster when I left the phone in the car I think the bluetooth stays active
[snapback]57691[/snapback]
Activating a constant Bluetooth signal on your phone will suck the life out of your battery in no time..
Old Nov 18, 2004 | 08:09 AM
  #42
Hormazd's Avatar
Originally Posted by wassy' date='Nov 18 2004, 10:07 AM
[quote name='roost' date='Nov 18 2004, 10:54 AM']I noticed that my battery drained faster when I left the phone in the car I think the bluetooth stays active
[snapback]57715[/snapback]
[/quote]
Yup. Major draw back of BT. If you are going for a long drive you need a car charger
Old Nov 18, 2004 | 09:52 AM
  #43
Wiu-Bimmer's Avatar
With the CPT9000, when you are using it in the car, it is constantly being charged, so you always have a Full battery
Old Nov 18, 2004 | 01:42 PM
  #44
roost's Avatar
My Ride: (Expecting Oct. 2004) 2005 530i Sport package, premium sound package,premium package, xenon's, HUD, sat radio, cold weather package, navagation
I put my phone on a car charger in the back of the consol and put the phone in the pouch behind the passenger seat only problem when the car is not running the battery is not charging
Old Nov 19, 2004 | 09:03 AM
  #45
Arno's Avatar
My Ride: 2004 530i - Cold Weather Package, Premium Package, Premium Sound, Steptronic, Comfort Seats, PDC, Xenon, Electric Sunshade
Originally Posted by Hormazd' date='Nov 18 2004, 02:35 AM
Doesn't seem like you have NAV.? I am not sure how different the voice commands for non NAV cars are.? Maybe thats one of the limitations.
Look on the information page of this site and download the list of voice commands.? They all seem to work for me.
I do not have NAV in my car. I downloaded the commands, and only seems like some of the phone commands will work. I still can not dial by name, it tells me that the phonebook is empty
Old Nov 19, 2004 | 09:18 AM
  #46
GER_545SMG's Avatar
Originally Posted by wassy' date='Nov 18 2004, 07:33 AM
[quote name='Hormazd' date='Nov 18 2004, 01:35 AM']
I was chatting with my brother through the car.? I parked,? wanted to leave the car, but continue the coversation.? I expected that turning off the car would break the BT link and the phone would then prompt me to use the handset.? (this is how it works with the headsets).? So I turn off the car,? remove the key from the ignition.? The phone call is still active through the car.?? So I got out,? shut the door, locked the car and started walking away with the phone.?? I can still hear my brother still talking to me in the locked car.? V. Weird.
[snapback]57565[/snapback]
Had the same thing on the X5 Bluetooth. It is a "feature" believe it or not, so that if you stop the car, and have a conversation going, you don't have to use the gas while you are talking. If you keep walking away from the car, about 30 feet, it will transfer back to phone, as th BT link would be broken at that point.
[snapback]57675[/snapback]
[/quote]\
I think it may "take the ball" if you press the button on your headset/handset. Try it, it is impractical and rude to have someone wait while you walk 30 feet!
Old Nov 19, 2004 | 01:12 PM
  #47
Wiu-Bimmer's Avatar
Originally Posted by Arno' date='Nov 19 2004, 12:03 PM
[quote name='Hormazd' date='Nov 18 2004, 02:35 AM']
[snapback]58117[/snapback]
[/quote]
You will be able to dial by name, if you firs use voice command "Save name" and save the name and number. That is the disadvantage for us without NAV
Old Nov 20, 2004 | 12:54 PM
  #48
Arno's Avatar
Originally Posted by Wiu-Bimmer' date='Nov 19 2004, 06:12 PM
[quote name='Arno' date='Nov 19 2004, 12:03 PM'][quote name='Hormazd' date='Nov 18 2004, 02:35 AM']
[/quote]
[snapback]58202[/snapback]
[/quote]
Thank you, that worked.
I am guessing that there are two phone books then? The one that transfers to the iDrive from the cell phone and then the phonebook that I create by doing the save name (and number), which does not display in the iDrive. Correct?
Thanks ....
Old Nov 24, 2004 | 06:38 PM
  #49
Ashish
Guest
Posts: n/a
Thumbs up
I have a 2005 530 with Nav and IDrive and a Cingular V600. I can get the car to pair with the car and to make and receive calls, but I cannot seem to get the phonebook to transfer over. Everything I have read seems to make me think this is an automatic process. Is there something I need to do that is missing to make this work or could this be a bug with my phone/car?
As a side note I also have a Razr V3 and had the same results when trying to pair this phone with the car... Handsfree operations work perfectly but no phonebook information gets transfered.
Any help would be greatly appreciated!
Old Nov 24, 2004 | 07:05 PM
  #50
Hormazd's Avatar
[snapback]60485[/snapback]
Transfer the phonebook to the phone from the SIM. Then just be patient. Resist the urge to use the phone or check the address book. Go for a half an hour drive and then check it.
