645Ci Satellite Radio Antenna Location
Hi,
Does anyone know where the antenna is mounted on the 645Ci Coupe?
I know the 545i has it in the shark fin, but the 6 doesn?t have a shark fin.
Thanks
DZ
Thanks
DZ
GPS, Bluetooth and SAT Radio all tucked up under the composite material trunk lid in two multi-freq antennas.
My Ride: G30 M550i
Model Year: 2018
cobradav is correct that the multi-band antenna is located under the trunklid. The only thing I'm confused about is that TIS only shows one antenna, not two...
E63_replacing_multiple_band_antenna.pdf
Originally Posted by Rudy' date='Sep 4 2005, 10:58 AM
cobradav is correct that the multi-band antenna is located under the trunklid.? The only thing I'm confused about is that TIS only shows one antenna, not two...
Attachment 10177
Attachment 10177
[snapback]166813[/snapback]
My Ride: G30 M550i
Model Year: 2018
The amplifier (for the diversity antenna) is located in the rear left roof pillar. That should explain why you don't have one inside the trunk lid...
E63_replacing_antenna_amplifier__diversity_.pdf
Originally Posted by Rudy' date='Sep 4 2005, 06:22 PM
The amplifier (for the diversity antenna) is located in the rear left roof pillar.? That should explain why you don't have one inside the trunk lid...
Attachment 10180
Attachment 10180
[snapback]166908[/snapback]
While I see this TIS it reminds me do u have anything on removing that rear headrest they mention in this TIS?
That rear window is a bitch to clean and it could be much easier if the headrests came out easily.
My Ride: G30 M550i
Model Year: 2018
Here you go cobradav, it looks as if it's as easy as the front ones...
E63_replacing_rear_head_restraints.pdf
Attachment 10181
Attachment 10181
[snapback]166950[/snapback]
I give that the ol' college try tomorrow (well later today now).
Attachment 10181
Attachment 10181
The results:
Bank$hot530
07-12-2015 04:36 PM
