Hi,
Does anyone know where the antenna is mounted on the 645Ci Coupe? I know the 545i has it in the shark fin, but the 6 doesn?t have a shark fin. Thanks DZ |
GPS, Bluetooth and SAT Radio all tucked up under the composite material trunk lid in two multi-freq antennas.
1 Attachment(s)
cobradav is correct that the multi-band antenna is located under the trunklid. The only thing I'm confused about is that TIS only shows one antenna, not two...
Attachment 10177 |
Originally Posted by Rudy' date='Sep 4 2005, 10:58 AM
cobradav is correct that the multi-band antenna is located under the trunklid.? The only thing I'm confused about is that TIS only shows one antenna, not two...
Attachment 10177 [snapback]166813[/snapback] |
1 Attachment(s)
The amplifier (for the diversity antenna) is located in the rear left roof pillar. That should explain why you don't have one inside the trunk lid...
Attachment 10180 |
Originally Posted by Rudy' date='Sep 4 2005, 06:22 PM
The amplifier (for the diversity antenna) is located in the rear left roof pillar.? That should explain why you don't have one inside the trunk lid...
Attachment 10180 [snapback]166908[/snapback] While I see this TIS it reminds me do u have anything on removing that rear headrest they mention in this TIS? That rear window is a bitch to clean and it could be much easier if the headrests came out easily. |
1 Attachment(s)
Originally Posted by Rudy' date='Sep 4 2005, 10:04 PM
Here you go cobradav, it looks as if it's as easy as the front ones...
Attachment 10181 [snapback]166950[/snapback] I give that the ol' college try tomorrow (well later today now). |
Anyone that hits an E63 from the rear is gonna cost his insurance company dear!!
1 Attachment(s)
Attachment 10181 [snapback]166950[/snapback] The results: |
