can 22" rims fit an 04 545i?
22s will fit with the proper tires and proper offsets. you may have to roll your fenders if needed. check out member wheelzplus. he has 22s on his e60, and a new member is planning to put 22s on his in the near future as well.
Originally Posted by bahamutzyro' post='540898' date='Mar 6 2008, 10:21 PM
22" rims on a 545i 2004? can it work without issues?? if so what would one need???
thanks!!!
thanks!!!
WHY?
Bill P
My Ride: FOR STARTERS I LOWERED THE CAR USING H&R SPRINGS. I CHANGED THE EMBLEMS TO BLACK AND CARBONFIBER ALSO ADDED CARBON FIBER DOOR SILL COVERS. I PUT ON A SET OF 22X9 - 22X10.5 AZA FORGED MYSTIC 2TONE BLACK AND MACHINED WRAPPED IN PIRELLI P ZERO NERO 245/30/22 AND 285/25/22. AC SCHNITZER REAR TRUNK SPOLER. ZENETTI BODY KIT CONSISTING OF A FRONT LIP, SIDE SKIRTS AND REAR APRON. RECENTLY ADDED 12INCH ANNIVERSERY EDITION JL SUB POWERED BY A JL 500X1 AMP IN A CUSTOM ENCLOSURE WRAPPED IN CARBON AND AUBURN VINLY WITH PLEXI. AUXILARY INPUT WITH IPOD ADAPTER.
Originally Posted by Bad Bimr' post='541034' date='Mar 7 2008, 04:39 AM
WHY?
Bill P
Bill P
WHY WHAT?
Originally Posted by wheelzplus' post='543352' date='Mar 12 2008, 12:46 AM
WHY WHAT?
OK let's take a nice car with great suspention (read handling) and totally F it up by adding an out of spec and overweight wheel/tire combo that will through of the suspention geometry out of whack. At the same time let's destroy the ride quality. The car and it's components was not designed for a 22" wheel. It is too large and too heavy. Basically doing so is like throwing away all the million dollars in engineering cost BMW put into the car.
I saw an E36 the other day with 22" rims. It looked HORRIBLE.
BP
My Ride: 2008 550i, Sport Package, Cold Weather Package, Nav, Jet Black, natural brown interior, automatic, Logic 7, ipod, lane departure warning.
Originally Posted by Bad Bimr' post='543458' date='Mar 12 2008, 07:14 AM
Why would anyone want to do such a thing?
BP
BP
Originally Posted by PlatinumEdition' post='543507' date='Mar 12 2008, 10:23 AM
u could fit 22s, need to roll fenders and if you take hard turns they will rub a little
The smallest 22" tire that I found is a 245/30R22. This tire is 2" taller the the stock (225/50R17). Rolling fenders will not help. You will need to raise the car (use thinker spring perches) so the wheels do hit the wheel wells.
You could fit anything including 24's if you really wanted, but again WHY?
BP
...pls don't...
