Low coolant Level
Hi,
I got problem in my 545 e60 with low coolant level. I top up it and after one week I need another one liter. Does anybody have got similar problem? Casue my mechanic cant find any leaking
I will be gratefull for any suggestions.
My Ride: F02 LCI Individual
Model Year: 2013
I just sent you a PM and hope I am wrong.
I just had the problem described in the PM and can tell you, some people buy complete cars for the amount needed to fix it.
Are you talking about this pipe whis is nr 3?
http://bmwfans.info/parts/catalog/E60/Seda...mounting_parts/
If o-ring is broken does water mixing with oil?
My Ride: 2004 545i Black Sapphire Metallic - RPI Exhaust, RPI scoop
Originally Posted by bzq' post='1047187' date='Nov 4 2009, 04:53 PM
Hi,
I will be gratefull for any suggestions.Hey I'm actually having the same problem right now.
Iceman can you tell me what was wrong with your car?
the O-ring / coolant pipe is a mojor problem with the 4.4litre engines
http://www.bimmerfest.com/forums/showthrea...;highlight=weep
http://www.bimmerfest.com/forums/sho...d.php?t=378610
I looked at this "weep hole" which is from the pipe and I cant see any leaking there but i put my hand under water pump and there was some coolant water but not a lot. Is is possible that water pump leaking a little?
