Low coolant Level
Old Nov 5, 2009 | 03:03 PM
  #21
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
It should come out there.
So maybe you are lucky and it's not the pipe leaking...
OTOH, it is possible that it leaks to the outside of the engine and the water comes down at the water pump, when the O-Ring is not yet totally broken...
Old Nov 5, 2009 | 03:15 PM
  #22
bzq's Avatar
bzq
I should knew everything at 16.11 cause my mechanic will take my pump out. I belive we should see what happends when pump will be off.
Old Nov 5, 2009 | 03:34 PM
  #23
porsche911targa's Avatar
Originally Posted by Iceman' post='1048252' date='Nov 5 2009, 05:03 PM
Correct, unless a legal problem.
Case is pending, I'm still in contact with BMW, I'll adress this later on the forum.
Currently, there's not much I can do...
I'm also still putting together all the infos and am trying to get as much details as possible.
Sorry to hear about this. Hope everything gets resolved in a most satisfactory way.
Old Nov 6, 2009 | 11:32 AM
  #24
gary belfast taxi driver's Avatar
Originally Posted by bzq' post='1048211' date='Nov 5 2009, 05:26 PM
Where is this switch? Can you show me on realoem?
It is a unit with fins on it at side of engine, it allows water and oil to pass through unit.
Old Dec 6, 2009 | 12:50 AM
  #25
tbal's Avatar
My Ride: See sig :)
scary stuff, been reading a lot of these issues on the 4.4 motors...
Any way to catch this problem early? Symptoms etc? BMW should do a recall, $8000 is absurd, tim<div align='left'></div>e to switch to benz? Perhaps...
Old Dec 6, 2009 | 08:11 AM
  #26
augustrush42's Avatar
My car also has this problem I top it off with BMW coolant and 2 weeks later it says Coolant Level Low
Old Dec 6, 2009 | 08:33 AM
  #27
05545i's Avatar
My Ride: 2005 545i Sport 6MT
Are you guys referring to the "weep" hole on the waterpump or some other weep hole?
Old Dec 6, 2009 | 10:00 AM
  #28
05545i's Avatar
well i just looked and it looks like there is a little weep hole behind the waterpump on the timing cover. Is that what you guys are referring to?
Old Dec 6, 2009 | 07:17 PM
  #29
sunny_j's Avatar
My Ride: 2003 760li
here is a cheaper fix
http://www.allgermanauto.com/products/expa...-pipe-tube.html
http://www.youtube.com/AllGermanAuto.../0/UoCED1jyfL4
umichchris
Dec 7, 2015 03:33 PM
knklhead
Aug 20, 2015 08:40 PM
Seedster
Aug 11, 2015 01:49 PM
turbo_mustang12
Aug 3, 2015 09:53 PM
bifajv
Jul 30, 2015 05:37 PM
