Low coolant Level
Old Nov 5, 2009 | 07:30 AM
porsche911targa's Avatar
Originally Posted by Iceman' post='1047219' date='Nov 4 2009, 05:28 PM
I just sent you a PM and hope I am wrong.
I just had the problem described in the PM and can tell you, some people buy complete cars for the amount needed to fix it.
Iceman, excuse me for asking, but weren't you the one who asked members not to PM where possible since other members might be interested in the answer or was it the other way around? I don't remember. Heck, I can't even remember what I had for dinner last night.
Old Nov 5, 2009 | 07:36 AM
NguyenAzn's Avatar
My Ride: 525i
hey guys, how do you check ur level of coolant ?
Old Nov 5, 2009 | 07:53 AM
Vyce77's Avatar
By using the search button
Old Nov 5, 2009 | 09:14 AM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Originally Posted by Iceman' post='1047259' date='Nov 4 2009, 03:04 PM
I just replied to you both by PM.
I too have an 04 545i.
TIA
Old Nov 5, 2009 | 09:38 AM
Blizz's Avatar
My Ride: 2004 545i Black Sapphire Metallic - RPI Exhaust, RPI scoop
I'll be taking my car in to the shop tomorrow and will keep you all posted on what they say.
I'm fairly confident that this is the same problem that some of the folks on bimmerfest are having
with the coolant crossover pipe and O-ring.
I took my car in to get this leak fixed about two weeks back and they said they fixed it but
everyday after work, i still see a small spot of liquid underneath my car near the right front tire.
Iceman was telling us that the crossover pipe and O-ring is actually a cheap fix but the engine
needs to be taken apart in order to get to it. Therefore the cost of this fix is exponentially increased
by the BMW stealership to compensate for the labor of taking it apart. The price he got quoted was
around $8,000! ...that is unacceptable! This clearly seems like a design flaw on BMW's part.
Click on the link bzg posted above and it shows you the layout of the engine and you can see that the
crossover coolant pipe and the O-ring are a part of the assembly .
I have a CPO and so I am still under warranty...so lets see what my service adviser tells me.
If any of you guys are driving around in a 2004 545, please make sure you check your cars for this
issue.
Old Nov 5, 2009 | 10:18 AM
NPe's Avatar
NPe
My Ride: M6 E63 Sapphire black Z3 Coupe R4Turbo Hellrot, semi race. (670bhp) Z3 Coupe V8Turbo design work ongoing, full race. Sold: 545i Titanium Silver
My car leaks i tiny winy bit in the hose #3
http://www.realoem.com/bmw/showparts.do?mo...hg=17&fg=05
Where #4 is attached. Probably a bad o-ring.
Will tear it apart and have a look.
That sounds like the same position you might have if it is dripping in front of the right tire.
I suggest you dig down with your hand and feel if it is wet around the #4 connector.
Old Nov 5, 2009 | 10:19 AM
gary belfast taxi driver's Avatar
Originally Posted by bzq' post='1047187' date='Nov 4 2009, 05:53 PM
Hi,
I got problem in my 545 e60 with low coolant level. I top up it and after one week I need another one liter. Does anybody have got similar problem? Casue my mechanic cant find any leaking I will be gratefull for any suggestions.
I had a similar problem it was the heat exchange which had to be replaced.
Old Nov 5, 2009 | 12:26 PM
bzq's Avatar
bzq
Originally Posted by gary belfast taxi driver' post='1048106' date='Nov 5 2009, 08:19 PM
Where is this switch? Can you show me on realoem?
Old Nov 5, 2009 | 01:03 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Correct, unless a legal problem.
Case is pending, I'm still in contact with BMW, I'll adress this later on the forum.
Currently, there's not much I can do...
I'm also still putting together all the infos and am trying to get as much details as possible.
Old Nov 5, 2009 | 02:50 PM
bzq's Avatar
bzq
Iceman, should this "weep whole" be wet when the pipe is broken?
Cause today I looked at this "weep whole" and in mine car is not wet, so the coolant water doesn`t leaking there I think. But I put my hand under water pump and there was wet.
