resetting oil change in idrive
Old Oct 28, 2005 | 06:05 PM
kreate2's Avatar
how do i reset oil change overdue in idrive? i changed the oil but it is still shows overdue warning.
Old Oct 28, 2005 | 08:51 PM
AC_S5's Avatar
The dealer does that for you, did you change your own oil?
Old Oct 28, 2005 | 09:03 PM
stafli's Avatar
My Ride: E61 525iA Build 2004/08. "Safirschwartz Metallic". Navi Pro, Adaptive Headlights, Bi-Xenon, Panorama Sunroof etc... CIP 18.00.01 (No noticed bug)
On the previous models this was easy (a cheap tool could be used). Now the dealer has to connect a computer and give some pretty advanced commands. You can probaly find software and interface on the open marekt for a DIY.
Old Oct 28, 2005 | 10:48 PM
nicke60gre's Avatar
[snapback]190322[/snapback]
Hi kreate2
Welcome aboard
Press the tacho reset button in the instument cluster about 10 seconds with the key to on position, until "service" appears, then change selection with a sigle push
until "engine oil" appears. Keep pushing the "reset " ask yes? and that's all. Next oil change after 25000 Km appears on the idrive "service"menu.
Beware, not to reset another function, there is no way to restore a reseted item.
Regards.
Old Oct 29, 2005 | 01:04 AM
norham's Avatar
My Ride: 2004 520i, mystic blue, steptronic, beige leather, pdc, bluetooth, rain sensor, BMW sport kit fitted, 18" 166 rep BMW rims , de-badged, cherished reg. chrome grill,
:thumbsdown:
[snapback]190386[/snapback]
Old Oct 29, 2005 | 11:41 AM
Ricracing's Avatar
Regards.
[snapback]190405[/snapback]
[/quote]
Does this really work????
I wouldn't even try it, 'cause I trade my car every 2 or 3 years.
I usually find something that the could improve at the dealers service.
Why try to save <?50 for a hillbilly bulls**t trick like this?????
Old Oct 29, 2005 | 12:17 PM
nicke60gre's Avatar
[/quote]
[snapback]190605[/snapback]
[/quote]
I did it on mine three times.
once for oil change, (second change - 40000 km - 2 years)
once for brake fluid change (2 years) not changed Because of 40000 km.
& once for the microfilter (not changed - Just cleaned)
It works.
Try it, but don't reset any item. Just to understand the way it works.
Old Oct 29, 2005 | 02:28 PM
E60Sim's Avatar
So nice!!!
When the warrenty and the free service is ended, I will do the oil changes, and change Micro filter etc.. The brakefuild and other bigger jobs, I will let my dealer take care of!
But a simple thing as a oil change you can do your selfe !
Old Oct 29, 2005 | 09:46 PM
norham's Avatar
Regards.
[/quote]
where do you get your oil changed for 50 euro?????????? seems like you use hilbilly's
Old Oct 30, 2005 | 10:24 AM
kreate2's Avatar
thanks for the help. had first oil change after warranty.
