V6.1 LCI retrofit cables with Special Brake light (Ricky Brake)
Old Jun 13, 2011 | 05:04 PM
  #121
saltdog's Avatar
My Ride: 2008 BMW M5
Got my V6.1cables today, thanks Bruce! I didn't have any issues with DHL, and mine also went through Cincinnati. I missed the first delivery, but they were willing to make a second trip.
Old Jun 14, 2011 | 07:27 AM
  #122
Terras14's Avatar
Hi i got my V6 too today. DHL came yesterday and no one was around. Today i decides to track it using the number Bruce gave me and saw it was delivered 30 mins ago. Called home and it was there...great service by DHL for making 2 trips and updating it real time. waiting for my cli tail lamp now...
Old Jun 14, 2011 | 01:23 PM
  #123
Frane 535d's Avatar
Hi! I've received my cables today and it's already on the car. Thanks Bruce! Looks great!!!
But! Only the inner light lights up when I step on the brake. Is that like on the original? Is there a possibility to connect the outer light with the inner to make both ligts light up when I step on the brake? Can I connect it directly with wire and is that dangerous for the modules (overload)?
Thanks for advice!
Old Jun 14, 2011 | 02:03 PM
  #124
bruce_miranda's Avatar
Thanks for advice!
The outer brake light is for the Brake Force Display. It will come on when you press the Brake hard. If you have a car that is newer than Oct 2006 you can join both the green and the grey wires and both lights will work, if you do this on a car that is older than Oct 2006 you will get an error on the idrive.
  #125
Thanks for advice!
Or if you can code your car, there is a coding hack that I posted on this forum to allow you to put both brake lights on.
Old Jun 14, 2011 | 02:15 PM
  #126
bmwfive's Avatar
Will this still pass a UK MOT without this light functioning?
Old Jun 14, 2011 | 02:16 PM
  #127
Frane 535d's Avatar
Thanks Bruce for the quick response! I think it's better not to touch it.
Old Jun 14, 2011 | 02:45 PM
  #128
If you look at your current pre-LCI, you will notice that's the same as well. One Brake light doesn't come on until you press the Brake hard. I have simply interchanged the positions of the Brake bulbs from Outer to Inner. So YES, these will pass UK MOT.
Old Jun 15, 2011 | 12:02 AM
  #129
Frane 535d's Avatar
Can I change the position of the brake bulbs so that the outer bulb lights up when I push the brake pedal? How can I do it?
Old Jun 15, 2011 | 04:37 AM
  #130
bmwfive's Avatar
Thanks Bruce.
