What do you guys make of these suspension settings
So this INPA program, is it mainly for checking and changing settings? What are the top common uses for a DIY person?
My Ride: 535D Tourer - Pre LCI
Fault codes mainly, i believe its the factory system or something very similar.
I've only had a it a couple of weeks and found that i can sort fault codes, live data such as what my injectors are doing, battery voltages etc. You can then open certain modules up and play with settings (like i have with the suspension). I would think that theres a lot more than i've described
There are also several other programs out there, Progman which apparently gives about 20 options to adjust, none OEM stuff - so if you wanted your folding mirrros to close off the key fob etc.
NCS expert - professional coding system...
to name but 2, thinks theres about 10
Awest91
09-17-2022 11:05 PM
am1296
10-07-2003 04:24 AM
