Want to put battery in trunk on battery tender
Old Apr 20, 2014 | 04:36 AM
Cpalacay's Avatar
My Ride: 2009 E61 535i Touring
Originally Posted by norsecarnut
Yes, regarding coding for a change of battery to new type. BMW Seattle quoted 1hr labor but I'm going to ask around as I can't imagine it takes more than 15 minutes or so.
Yeah, I went thought the same saga when I swapped out the battery last fall. I just couldn't live with myself if I went ahead and paid what BMW Seattle wanted for a new battery plus the 1hr labor for coding.
I ended up buying the battery from Autozone for ~$165 and coded it myself through INPA. Total time for coding, 2 minutes. I'd be happy to register it for you.
-Christian
Old Apr 21, 2014 | 09:40 AM
Lotus99's Avatar
Christian, Did you buy the same specs battery, or upgraded to AGM too?
Old Apr 21, 2014 | 04:52 PM
Cpalacay's Avatar
I upgraded to AGM. I didn't go as far as reprogramming, just registering the new battery. I haven't had any issues since the replacement, but if it goes out within 3 years I can swap it out for a new one under warranty.
-Christian
Old Apr 21, 2014 | 09:16 PM
Lotus99's Avatar
Hey Cpalacay, Can you post up the brand and model and specs of the one you got? I've got a cable on the way, and will learn how to register a new one hopefully if not too hard.
Old Apr 21, 2014 | 10:35 PM
norsecarnut's Avatar
My Ride: 2008 535xiT6
-Christian
Your charging system will be slowly damaging the new battery then. Most likely not enough to fail in 3 yrs but rather in 38 months when your warranty is no longer valid....
Old Apr 21, 2014 | 10:39 PM
-Christian
Thank you for offering! Can what you have also allow access for the coding? I will not be taking my chances like you are I just spent $370 on a battery so I'm going to make it last well beyond the warranty on it. The 2150 in my land rover is still perfectly good after 7 years.
Old Apr 22, 2014 | 07:23 PM
Lotus99's Avatar
What did you get?
Old Apr 22, 2014 | 10:23 PM
the 1350 Odyssey
Old Apr 23, 2014 | 08:38 AM
Lotus99's Avatar
Originally Posted by Lotus99
when I opened up my trunk liner to look at mine, it is a lead acid battery with a 110 amp hours (reserve capacity) and 850 Cold cranking amps (CCA).
the 1350 Odyssey
Wow, that's one expensive battery at almost $400!
It says its specs are:
CCA: 770A at 0°F (-18°C)
Capacity @ 20 hour rate: 95
Which is less than stock on both counts. Why would you get it then, even if it's an AGM?
Old Apr 23, 2014 | 10:19 AM
AGM batteries are different. It's still better than the oem. Reserve is actually 195 min.
