Touring rear suspension failures
Old 05-26-2009, 05:05 AM
Patrick E61's Avatar
My Ride: 2005 BMW 530d M-Sport TouringExterior: Titansilber Metallic, M5 mirrors, ACS rear roof spoiler, BMW Carbon Fiber rear diffuser, Adaptive Xenon headlights, AngeliBright v.3 Angel Eyes, F1 Autohaus Euphoria 6000K LED license plate lightsInterior: Black
Originally Posted by narvselius' post='890331' date='May 26 2009, 03:59 PM
... maybe it's a result of the re-design last year that they now only need to supply a lot of hoses instead?
Yep. My mechanic even told me that he has replaced more than a dozen of the hoses. They all knew about the hose re-design as well.
In the past, the entire unit would be replaced when the car was still under warranty.
That said, it sucks for those of us out of warranty and with destroyed compressors.
Jokingly, I mentioned that probably I am looking at having to replace the wiring harness to the rear door (as mentioned in other threads here). Mechanic simply smiled and said, "Yes."
Old 05-26-2009, 05:57 AM
master's Avatar
My Ride: '06 530xi sw
hello all.
Why does the hose go bad so quickly??? Is this caused by the debris picked up on the road?
For me, the whole air supply has gone bad in march (2 months ago! at 36K miles) and BMW replaced the thing.
Now I have to start worrying about the hose...
Is this a design flaw, and therefore shouldn't there be an SIB for this???
This sounds more and more annoying --- $60K car has a frequently failing $10 hose that has major impact on the car's suspension system?!
Old 05-26-2009, 06:04 AM
My guess is that you already have to improved hose if they just replaced everything else in March.
The problem for the hose can be attributed to road debris getting inside the cover for the compressor, and also in some cases, temperature fluctuations, moisture and so on. The hose goes bad and then the compressor sucks in dust, sand and grime, which then messes up some valves in the compressor. The compressor over-heats and eventually fails causing problems in getting the rear suspension up or down.
Removing the cover to see the compressor and hose takes about 3 minutes, so having checked out on a regular basis cannot hurt.
Old 05-26-2009, 06:07 AM
kErb's Avatar
My Ride: 2005 E61 525d M-Sport, Titanium Silver, Black Dakota Leather, Media Pack, Sun Protection Glass, M6 Staggered Alloys, ACS Rear Diffuser, EBC Green Stuff Brake Pads, I-Pod Interface. Rear Aux Power DIY, LCI Rear Lights, Extended interior lights - doors and footwells, LED licence plate lights.
Originally Posted by Patrick E61' post='890261' date='May 26 2009, 11:43 AM
I had the CF diffuser installed today, and once that was completed, we checked the compressor issue.
Sure enough, the tray under the compressor was full of mud, gravel, sand and some other road grime. Better yet, the dreaded compressor hose needs replacing. Otherwise, everything looked fine - no corrosion to speak of.
The service department did not have this hose in their inventory, so it is coming from Germany later this week. Then I will have it replaced.
Preventative action is key.
Just had a look at mine - and guess what, mines gone as well. I have shortened the pipe by 2 cm, and refitted with a new clip. The rest of the pipe looked okay, it was just split on the join to the compressor, I am hoping therefore that it should be okay.
I don't know if it would be safer to have the whole pipe replaced or not. I see mention in this thread of a redesigned pipe, is this reinforced or just plain rubber like the current one?
Does anyone have the part number for the redesigned pipe?
The only part number that I can find on; BMW Info Fans is 37206777361 which is priced at ?71.51. A lot cheaper than a new pump.
My car is just out of warranty (1 month), so I would no doubt need to sort this myself.
kErb
Old 05-26-2009, 08:59 AM
trevorken's Avatar
My Ride: BMW E61 520D 2007
Anyone knows when that improved hose is put in the car from the factory on?
Mine is from 11/2006.
Is it possible to have a look at it without having it in the air?
Old 05-26-2009, 09:02 AM
I didn't ask about this, but according to narvselius, it changed last year.
IMHO, it would be rather difficult to just get under your car, remove the cover and then look up there. It needs to be up.
Old 05-26-2009, 09:10 AM
trevorken's Avatar
OK, thanks. I'll ask the service people to have a look at it when I'm there next time.
Old 05-26-2009, 09:13 AM
I would suggest that you also ask to be there when they open the cover so that you can see what is up there.
They should give it a close-up inspection (with a light) and have a look at everything.
Old 05-29-2009, 08:03 AM
master's Avatar
Originally Posted by Patrick E61' post='890393' date='May 26 2009, 10:04 AM
The problem for the hose can be attributed to road debris getting inside the cover for the compressor, and also in some cases, temperature fluctuations, moisture and so on. .......
Thank you Patrick. This looks to me like a design flaw with the compressor cover, and the overall design of that portion of the car!
kilotus (09-01-2019)
Old 06-11-2009, 06:39 PM
Btw, the "upgraded" hose or pipe that they replace costs a whoping... (PLEASE BE SEATED)
105 Euros + installation
Quick Reply: Touring rear suspension failures
