Is there a dpf removal DIY?
Old 02-16-2013, 07:40 AM
Mikethepanel's Avatar
My Ride: 2006 525d M-sport,19" staggered style 95 wheels,custom quad exhaust with modified reiger rear bumper insert,LCI front and rear lights,stage 2 custom remap, DPF removed, cat removed
Default Is there a dpf removal DIY?
I had a quick search but can't find anything
I want to remove the dpf pipe from my 525d but it looks a nightmare
Old 02-16-2013, 10:01 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Does your car have a separate dpf under the car in the middle of the exhaust or is it combined with the catalytic converter which locates right behind the turbo?
- Antti -
edit: I'm asking because according to RealOEM, it is a separate can under the car (525d 2006), and that is extremely easy to remove. Whichever it is, you need coding too if you're planning to remove the DPF completely.
Old 02-16-2013, 10:22 AM
- Antti -
Its right up behind the turbo
Old 02-16-2013, 10:25 AM
Anzafin's Avatar
Oh! I guess you have checked it yourself, right?
That is trickier then and I'm sorry I have no info about that.
- Antti -
Old 02-16-2013, 11:13 AM
Thanks then
Its mainly for the top of the thing on the back of the turbo, how the hell are you suppost to get to the bolts?
Old 02-16-2013, 11:43 AM
Anzafin's Avatar
I have TIS, I can check if I can find removal instructions for you...
- Antti -
edit: Even TIS claims that you have a separate DPF under the car, but I'm searching for those another instructions...
edit2: You're right. It seems that the newer M57T2 has the combined DPF + catalytic converter. Found the instructions. Will post them here soon...
Old 02-16-2013, 12:00 PM
Anzafin's Avatar
Ok, this is what TIS says:
1) Remove the underbody protection
2) Remove the bottom reinforcement place
3) Remove the exhaust
4) Remove the DPF
Not so difficult I would say, but laborious.
I hope this helps.
- Antti -
File Type: pdf
File Type: pdf
Old 02-16-2013, 01:08 PM
Thank you Antti
Old 06-27-2013, 12:14 AM
andy007's Avatar
when you say 2) Remove the bottom reinforcement place, is that the triangular silver colour one, I was worried, I thought that held something important on? How do I know where my dpf is, once the large plate is off I guess i see it?
Old 06-27-2013, 01:05 AM
andy007's Avatar
It looks like it might be up higher, or can it be in the box in the centre of the car, if it is that one it doesn't come off, only the whole exhaust middle
Quick Reply: Is there a dpf removal DIY?
