Number Plate light Right Failure / Tailgate wiring new
After changing the tailgate wiring (every wire soldered + heatshrink)I still have the number Plate light Right Failure
Checked the wire from the original wire (next to the speaker) and no juice when lights are on or not
Have ordered a snake camera to check were the cable goes after the speaker / Also checked all the fuses and all is good
Anyone has a clue? where does the cable connect to so that I could check if there is continuity between the 2 ends? i guess it doesn't just connect to the light switch...
Thanks
Thanks
It turned out that the output had been permanently disabled in the LM module due to too many short circuits.
I used Tool32 to reset the short circuit counter. After that, the output became active again and the license plate light started working.
