$tealer wants 2500 to replace both tailgate wiring harnesses. options in Seattle ?
Old 09-20-2017, 04:21 AM
Appbwg's Avatar
My Ride: 2007 e61
Originally Posted by E60Japanese
Are you sure you need to replace it?
What's the problem?
Not sure. However , Both Right backup lamp and right brake lamp in tailgate do not work, nor does the rear window wiper.
Upon inspection of wires/loom inside right hinge cover, I can see other wires have been compromised and skinned.
This thread and forum has been most helpful.
Old 09-21-2017, 10:35 PM
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
Usually near the hinges the loom becomes hard and brittle and breaks
If you have a test lamp check the power either side of the hinge to see which wires are not completing the circuit
Old 09-24-2017, 03:15 PM
Appbwg's Avatar
My Ride: 2007 e61
Was as able to obtain wiring diagram. After inspecting at hinge I cut and spliced all wires, cutting at tailgate hinge and pull through to speaker. Three were completely broken and two others were skinned.
Since I was in there it was sensible to replace them all. Solder and shrink wrapped all wires taking no chances. Well worth the time and effort as all tailgate lights and functions work.
both bulb malfunction warnings went away. Woo hoo.
Old 09-26-2017, 10:20 PM
Congratulations! Well done
Old 09-27-2017, 04:05 AM
Appbwg's Avatar
My Ride: 2007 e61
Thanks. Any idea about rear washer fluid?. Reservoir is full, fluid sprays fine on front but none comes out back when I press the wand forward. I inspected the nozzle and blew some compressed air in it.
Old 11-06-2017, 12:12 PM
jadedj's Avatar
My Ride: 2010 BMW 535x iDrive MT
Model Year: 2010
Engine: N54
I just purchased a E61 and this is EXACTLY what is happening with my rear struts. Thankfully, everything still works but I can see the rust and it looks like I'll be doing the replacing of them as well as some other fixes.
Pretty sure this is what I need:
BALL PIN . M10 Part Number: 41627148797
RIGHT GAS PRESSURIZED SPRING . 315N Part Number: 51247201468
And hopefully not this:
Hydraulic cylinder Part Number: 51247163662
Has anyone done this recently? I did it on my wife's Touareg but not sure how much more difficult this is. Thanks!
Pics attached:
Old 11-06-2017, 06:00 PM
It’s very very easy
Simply put a screwdriver detergent the rusted stir and the body and pop it off
Remember to get some to hold up the tailgate or it will fall on your head
Then you simply set the new strut in place and give it a hit with your hand and it will slip in place
Many for sale on eBay e61 rear tailgate strut
Old 11-07-2017, 10:09 AM
jadedj's Avatar
Model Year: 2010
Engine: N54
It’s very very easy
It's really that easy? I actually bought an OEM right strut and will let you know how it goes. Thanks
Old 11-07-2017, 04:27 PM
Yes it’s really that easy
Good luck!
Look forward to hearing your successes
rkundrat
06-30-2016 04:51 AM
Kurt Karasch
04-27-2016 08:24 PM
eondi66
04-23-2016 09:53 AM
Daveotto
04-22-2016 08:35 AM
DrLou
04-20-2016 05:37 PM
Quick Reply: $tealer wants 2500 to replace both tailgate wiring harnesses. options in Seattle ?
