This question is literally buggin me???
Old 03-18-2010, 12:35 PM
Shezmon's Avatar
My Ride: 09 M5 (E60) Interlagos blue, Silverstone interior, with cold weather package. Adaptive Xenon headlamps and adaptive brake lights, hud, comfort access. Comfort seats, basically fully loaded.
I have a pal who has an m3, says that after 50k miles all M cars need a valve adjustment or some timing adjustment that is very important for the car. It falls under the category of inspection 2. Any info plz shed some light. This is suppose to run around 1200 to 1500 dollars w/ the stealers.
Old 03-18-2010, 12:46 PM
miguex's Avatar
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Maybe find out in m5board.com. M owners there..
Old 03-18-2010, 01:14 PM
Aartsy19's Avatar
Lots of M owners here... but sorry i dont know
i find m5board harder to navigate.. much prefer e60
Old 03-18-2010, 02:01 PM
BMWM5NYC's Avatar
My Ride: 2007 E60 M5 Alpine White/ Indy Red 6spd
The S85 does not use solid valve lifters like the S54 engine does. Cars without solid
valve lifters do not need adjustments like the S54 (E46 M3) engine does.
I got this from a press release about the S85 engine>>
The one-piece aluminium cylinder heads of the V10 engine are arranged in banks. The V10 power unit features four valves per cylinder, a typical BMW trait. All valve train components are of low mass. Thus, for example, the M engines feature for the first time low-weight, flow-optimised 5 mm-shaft valves, spherical valve tappets with hydraulic valve play compensation and single valve springs. All this results in a considerable mass reduction, which is a prerequisite for the realisation of the high-revving concept.
"Hydraulic valve play compensation" = No valve adjustments like the E46 M3
Old 03-18-2010, 03:55 PM
skelevirus's Avatar
Model Year: 2019
yes every bmw needs an inspection 1 and 2, i believe inspection 2 happens at 90-100k miles and its a comprehensive tune up. at least it was on my '88 528. never made it that far w my e60/e90
Old 03-18-2010, 06:44 PM
Shezmon's Avatar
Exclamation
Thanx for the info champ... Very helpful indeed.
Old 03-18-2010, 07:03 PM
-Mike-'s Avatar
My Ride: 2008 550i sport
not sure about the M3
maybe i'm stating the obvious
e60 (including m5) moved to condition-based service monitored thru idrive
inspection 1 and 2 are irrelevant
Old 03-19-2010, 05:57 AM
Shezmon's Avatar
i believe you are correct my friend.
Old 03-19-2010, 07:48 AM
BMWPower06's Avatar
My Ride: E60 BMW ///M5 V10
On my E46 and E39 the Inspection 2 was at 60k miles. Never did it on either of em, the E46 I sold with 67k miles on it and it had no problems. The E39 currently has 110k miles on it, aside from a few new parts at 100k miles everything else is stock and working fine...
Old 03-19-2010, 03:14 PM
BMWM5NYC's Avatar
He is. Basically I drive tells you when and what type service you need. Then there are certain services that
are dictated with the service the car is calling for based on your mileage.
sterling01
F10 Discussion
09-20-2015 04:41 PM
aqualibrium
07-21-2015 03:11 AM
milkox
07-15-2015 09:48 AM
w84me
07-10-2015 10:56 AM
ST JAMES
07-03-2015 07:04 PM
Quick Reply: This question is literally buggin me???
