Doing it myself...
My Ride: 2006 530i - Sport - 6spd - Orient Blue with Auburn/Anthracite
Hi,
Does anyone have a document that outlines the procedure for removing the plastic shrouds on the bottom of a 5er? I'm considering replacing the CDV by myself but I am a little intimidated at the prospect of having to remove the shroud just to get to the clutch slave cylinder...
Any help would be appreciated.
Thanks, Jon.
Thanks, Jon.
Originally Posted by jmdhuse' date='Aug 15 2005, 05:14 PM
Hi,
Does anyone have a document that outlines the procedure for removing the plastic shrouds on the bottom of a 5er?? I'm considering replacing the CDV by myself but I am a little intimidated at the prospect of having to remove the shroud just to get to the clutch slave cylinder...
Thanks, Jon.
Thanks, Jon.
[snapback]159629[/snapback]
My Ride: G30 M550i
Model Year: 2018
Is this what you're looking for?
Step 1:
removing_front_underbody_protection.pdf
Step 2:
removing_rear_underbody_protection.pdf
Step 3:
removing_reinforcement_plate.pdf
Good luck...
Step 1:
Step 2:
Step 3:
Good luck...
Step 1:
Attachment 9638
Step 2:
Attachment 9639
Step 3:
Attachment 9640
Good luck...
Step 1:
Attachment 9638
Step 2:
Attachment 9639
Step 3:
Attachment 9640
Good luck...
[snapback]159677[/snapback]
I did find a mechanic willing to do this for me, but he hasn't worked on any of the E60 5ers because most people are still taking them to BMW for service under warranty.
Thanks, Jon.
If you do it yourself, or if the mechanic isn't familiar with the car, watch out for the catalytic converter! One mechanic told me he burned the #$%! out of himself the first time he replaced a CDV.
Originally Posted by wolverine' date='Aug 16 2005, 02:42 PM
If you do it yourself, or if the mechanic isn't familiar with the car, watch out for the catalytic converter!? One mechanic told me he burned the #$%! out of himself the first time he replaced a CDV.
[snapback]160001[/snapback]
chaudhrysn
10-19-2014 09:11 PM
ESMWheels
09-02-2011 10:37 AM
