Welcome Light and Pathway Lighting no longer working
Old 02-15-2012, 01:05 PM
Gizzler's Avatar
Today I noticed my welcome light is no longer working. I had my car coded to turn on fog light along with the welcome light when unlocking since like 5 months ago, and it had been working perfectly until today. I tested out and found out pathway lighting is not working either, (had my car coded to work with remote), now can't even trigger it with the turn signal lever.
FYI, I have LCI E60, and everything was working perfectly until today. and NO ERROR code shown on idrive. I have already tried changing the settings on idrive about welcome light and pathway lighting but no luck. All my lights are in perfect working order... Just not the welcome light and pathway lighting.
Does it ever happen to any of you guys? or any ideas?
I'd appreciate any of the inputs!!
Thanks.
Old 02-15-2012, 04:21 PM
T1000BP's Avatar
My Ride: 550i M SPORT - 6 SPEED MANUAL
Make sure your lights are set on Auto. You probably already know that, but just eliminating possibilities.
All these functions seized to work with me when my battery was dying. Apparently when the battery drops under a current voltage the car saves juice!
When I installed my new battery all these functions started to work again.
Maybe a failing battery?
Old 02-15-2012, 05:54 PM
NoQuarter's Avatar
Engine: N54
some of my lighting features quite working also when I was dealing with a dying battery. I just assumed I did something in my projects to change the settings but they came back after I replaced the battery.
Old 02-15-2012, 07:09 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
It's probably a battery issue.
There was a member that I helped with a few months back. His battery was around 2 years old if I remember correctly, but one day, he started to have electric gremlins. From my experience, it pointed to the battery. After he took it to a shop to do battery load test (which suggested the battery was fine), he then decided to just swap out for a new battery. After the new battery went in, everything went back to normal.
Old 02-15-2012, 07:27 PM
Gizzler's Avatar
Thanks guys!!
YES, battery is also my biggest doubt as of right now. I drove around for about 5 miles and came back, it all worked fine. Then after about a few hours i tested again and it stopped working again!! So, that most likely is the battery problems.
Any recommendation for a new battery,
I've read This Thread and a couple others. But just feel like I'd ask while I'm at this. Also do you guys recommend me to program the battery? Since I know I'll get both answers for this question, I might better off asking "where would you guys recommend me to get my battery programmed in SoCal (Los Angeles and San Gabriel Valley) area?"
Thanks again!!
Old 02-15-2012, 08:07 PM
Sublime's Avatar
My Ride: 2012 535i M-Sport
I've also noticed that after x amount of lock/unlock cycles WL gives up until I go for a drive. I have a new battery.
Old 02-15-2012, 08:56 PM
Gizzler's Avatar
No, that's the built-in system to preserve battery life.. What I'm talking about is today the welcome light and pathway lighting no longer working except once right after my 5 miles drive. Now even better, my idrive disconnected my phone call when I pulled out the key. Before if I pull out the key while I'm on my phone, the battery will power up the idrive and bluetooth to continue my phone call. :thumbsdown:
Definitely time to replace a new battery!! now debating which one I should choose and whether and where I should get the new battery registered by programming.
Old 02-17-2012, 04:11 PM
NoQuarter's Avatar
Engine: N54
I have no problem recommending this: Buy a $220 battery, stick it in your car and drive it.
I got an online price for an OEM battery, asked my local dealer parts manager if he could get me the online price and he did.
Old 02-17-2012, 11:25 PM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
Good Info to know , I'm still on original battery 5 1/2 yrs and counting.
Beemer
33
01-14-2019 05:13 AM
BMW565
11-06-2017 06:03 PM
bbbamboo
09-17-2017 04:33 PM
jhalsey
01-25-2004 04:34 PM
08-12-2003 11:41 AM
Quick Reply: Welcome Light and Pathway Lighting no longer working
