Ultimate Eyebrow Upgrade
Old 06-09-2010, 04:09 AM
  #331
nigxdoof's Avatar
Originally Posted by Que
How is it different for the 08 528i? I want to start the mod this weekend but I don't want any suprises.
The LEDS of a Pre-LCI 2004-2007 are different from the LCI 2008-2010. The new headlights have SMD LEDS.
Old 06-13-2010, 05:59 AM
  #332
IMTx's Avatar
Hi Eugene134, very nice what you did with the angel eyes.
I want to do the same but I don't understand how you do between IMG_2116.JPG and IMG_2118.JPG.
Have you more photos to explain how you did? Because I do the same as you to IMG_2116.JPG, but I don't know what to do next in order to be at the same step as IMG_2118.JPG.
Can you give us explanation or photos?
thank's a lot.
Old 06-13-2010, 09:08 AM
  #333
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
You cut the area around it, and take out the piece? Not sure where the confusion lies.
Old 06-13-2010, 12:17 PM
  #334
rctmthouse's Avatar
was thinking of doing this mod in the coming week but read in another thread that there was some condensation problem, has anyone else experienced the same problem?
Thanks
RCT
Old 06-13-2010, 01:55 PM
  #335
nigxdoof's Avatar
Thanks
RCT
If you cut it right and seal it right, you will not get that problem. Previous installations had that problem but the last 4-5 jobs I've done, including my own headlights have not had a problem.
Old 06-14-2010, 04:13 PM
  #336
suthurnbimmur's Avatar
My Ride: 2004 BMW 545i
+1, just take your time. Make a clean cut and when putting it back, scrape off any rouch edges, gaps will be filled when you seal it! other guys are the pro, I've only done mine so far
Old 06-16-2010, 06:03 AM
  #337
luluslc's Avatar
do someone know how to test the light, how to turn them on
Old 06-16-2010, 06:04 AM
  #338
nigxdoof's Avatar
Huh?
Old 06-16-2010, 08:15 AM
  #339
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Depending on which step you are at and how you want to turn them on.
I mean, literally the easiest would be to just plug it in, and turn the dial to parking light.
Old 06-16-2010, 08:54 AM
  #340
robg520d's Avatar
My Ride: 2010(60) BMW 520d SE, Manual, In Sophisto Grey with Cream/Black Interior and Piano Black trim
I've not looked too deep into it yet, but provided i can remove the section of headlight without a problem, can you recommend any particular process to follow to re-seal the light unit?
I read that there is a chance of some of the white LEDs purchased could end up being yellow, is there an easy way to check without actually installing them and finding out the hard way? I have a link to the following LEDs from the UK, shown below, can you please verify if these are the correct ones for the pre-LCI with standard halogen lights?
http://uk.farnell.com/jsp/displayPro...-2072-00001000
Cheers
Quick Reply: Ultimate Eyebrow Upgrade
