Snow Rim/Tires Question
Will 16" or 17" snow rims/tires fit on an E60? I am asking because there are some good deals on eBay that I would like to get.
example:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...me=STRK:MEWA:IT
thanks
PS - anyone have any BMW or general guidelines regarding aftermarket rim/tire compatibilty? that would be some very valuable information. i did a search on the board and it seems there have been many discussions about BIGGER rims, but I would llike to know what smaller diameter/width rims would work (of course because they will provide better snow performance)
example:
thanks
I beleive that the 16" will not clear the brakes on a 545i, they are larger than 530 & 525, so you will have to stick to the 17" minimum. Just make sure that the offset works or if you just get the stock 17" non sports package tires, will work.
Originally Posted by CRRobert' date='Feb 24 2005, 05:30 PM
I beleive that the 16" will not? clear the brakes on a 545i, they are larger than 530 & 525, so you will have to stick to the 17" minimum.? Just make sure that the offset works or if you just get the stock 17" non sports package tires, will work.
[snapback]93987[/snapback]
thanks in advance
My Ride: 2005 530i - Alpine white with auburn interior; tip, xenon, pdc, sirius, prem, cold weather, red reflectors and xpel.
If you go to BMW wheels they will show you what 17" rims will fit on an e60 (offset/bolt pattern). It will, however, not indicate if various rims will only fit a 530i vs. 545i. You will probably need to ask your dealer. It does appear a number of 7 series wheels will fit though.
Originally Posted by macct' date='Feb 25 2005, 11:49 AM
If you go to BMW wheels they will show you what 17" rims will fit on an e60 (offset/bolt pattern).? It will, however, not indicate if various rims will only fit a 530i vs. 545i.? You will probably need to ask your dealer.? It does appear a number of 7 series wheels will fit though.
[snapback]94265[/snapback]
thanks
yes, the web site. If you click on new wheels and select the e60, it will show what current styles will fit. Some of the 7 series wheels fit, but appear to be larger sizes.
It terms of the rims linked on ebay, they won't fit. They are from the previous generation 5 series (E39) and the offsets are different. In terms of the 7 series, there seem to be quite a few style 92s out there, but they are really not optimal for snows (18" wheels).
good luck searching.
Originally Posted by macct' date='Feb 25 2005, 01:07 PM
yes, the web site.? If you click on new wheels and select the e60, it will show what current styles will fit.? Some of the 7 series wheels fit, but appear to be larger sizes.?
It terms of the rims linked on ebay, they won't fit.? They are from the previous generation 5 series (E39) and the offsets are different.? In terms of the 7 series, there seem to be quite a few style 92s out there, but they are really not optimal for snows (18" wheels).
[snapback]94298[/snapback]
aqualibrium
07-21-2015 03:11 AM
