Should I tap the wire or not?
I used Don Juan's method to hardwire my Valentine 1 into the wire in the dome lights and it worked great. My question is I plan on installing a boost gauge in the next few days, so if I tap into the same wire that I tapped my V1 into (the green and yellow wire) this could potentially overload the wiring right? I'm trying to find another 12v source I can tap the gauge into but as of right now I have no idea.
My other question is the wiring I used to hardwire my V1 didn't have a built in fuse, could that be a problem also?
https://5series.net/forums/topic/708-radar-det/
Don Juan's hardwire install diy
Ok well I decided to not tap into the same wire, going to just run it to the fuse box and tap the fuses there.
My other question if the wiring I used to hardwire my V1 which didn't have a built in fuse, could be a problem also and if I should get a fused wire is still something I'm wondering about.
I personally would put a fuse inline ... cant be too careful .. and for the very minimal cost and time to do .. worth doing for that peace of mind....
Im looking for a boost gauge meself too .. do you have any pics or links of the one you are using ??
also where you tapped the boost feed from ??
Thanks
Thanks
spediegunz
08-30-2015 09:43 AM
