Problem on Brembo BBK
Hi Guys,
Just want to share some experience on my Brembo Front 8 Piston and Rear 4 Piston.
I took my car to the track. I stopped the car everytime after 3-4 laps. Total probably 10-12 laps.
After the session, everytime I brake, it makes very loud sound on the brake.
I checked to the dealer. The results, all the front pads (total 8 pcs) are cracking. Rear was okay. I'll post some pics.
Any idea?
Any idea?
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Maybe pads are not "beded-in" before you taken to the track??
Or pads are not in its "working temperature" before you brake hard??
Just my thoughts![Think](https://5series.net/forums/images/smilies/imported/think.gif)
Are they bembo pads?
Just my thoughts
Yap, Those are Brembo Pads.
I'm not sure about the working temperature. My friend was driving BMW M6, and there was no problem on his brake.
Weird... Isn't Brembo should be better than stock M6 pads?
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
Originally Posted by HS_01' post='536691' date='Feb 27 2008, 05:29 PM
Weird... Isn't Brembo should be better than stock M6 pads? ![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
Brembo is the best in the World .
Learn to use brakes, HS : very likely you are the problem .
bad breaks installation job for sure... :thumbsdown:
My Ride: MY2005 E60 525i M Sports
+1
Brake pads crack when they're overheated. Brembos or not, these particular pads may have been more street-oriented rather than good track pads. You should also consider if you're driving style contributed to the cracking. Or perhaps the pads were faulty themselves.
For braking style, I believe I did it properly. I've been attending several driving school with BMW and Ferrari.
No problem at all. This is the first time I have problem with pads.
Probably the outside temp at that moment was above 100 degree F. It was very hot.
I ask my dealer, the pads was defective. Probably bad batch.
carid
03-06-2015 04:58 AM
