Pre LCI Halogen to LCI Halogen conversion
Old Jul 10, 2011 | 03:39 AM
  #331
Sas's Avatar
Sas
My Ride: 520i ('04)
Now that i have a little time to spare i refitted the 5W LED's (i removed them after they throw iDrive errors) and coded LMA not to do the warm and coldcheck and the error is gonne.
Still have the issue that the HID's blink 3 times when i turn them on with the engine running, although i've coded LMA not to do the check.
No blinking when i set the lightswitch on auto nor when i switch the lights on (or set the switch to auto) before starting the car.
If i add $522 (Xenon) to the VO and code the car, the blinking is gonne.
But now the car thinks it has autoleveling, disabling the manual leveling switch in the car and starts to point the lights at random heights when i turn them on.
Code:
Generated with NCS Dummy version 0.5.0.0 ? copyright İ 2011 revtor software
Output       : Trace Differences
Chassis      : E60 (E60,E61,E63,E64)
Module       : LM_E60.C0E
Trace file 1 : ...\NCS Expert\TRC Xenon\LMA_FSW_PSW.TRC" (FSW/PSW)
Trace file 2 : ...\NCS Expert\Original TRC\LMA_FSW_PSW.TRC" (FSW/PSW)
Differences  : Yes
1   2   FUNCTION KEYWORD           FUNCTION KEYWORD TRANSLATION
            PARAMETER KEYWORD          PARAMETER KEYWORD TRANSLATION
        ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
        KALTUEBERWACHUNG_SL_V_R    COLD MONITORING PARKING LIGHT OR ANGEL EYE - FRONT RIGHT
*           aktiv                      active
    *       nicht_aktiv                not active
        KALTUEBERWACHUNG_SL_V_L    COLD MONITORING PARKING LIGHT OR ANGEL EYE - FRONT LEFT
*           aktiv                      active
        KALTUEBERWACHUNG_AL_R      COLD MONITORING RIGHT LOW BEAM
    *       aktiv                      active
        KALTUEBERWACHUNG_AL_L      COLD MONITORING LEFT LOW BEAM
    *       aktiv                      active
        KALTUEBERW_RL_BL_2_R
    *       aktiv                      active
        KALTUEBERW_RL_BL_2_L
    *       aktiv                      active
        WARMUEBERWACHUNG_SL_V_R    HOT MONITORING PARKING LIGHT OR ANGEL EYE - FRONT RIGHT
*           aktiv                      active
        WARMUEBERWACHUNG_SL_V_L    HOT MONITORING PARKING LIGHT OR ANGEL EYE - FRONT LEFT
*           aktiv                      active
        WARMUEBERW_RL_BL_2_R
    *       aktiv                      active
        WARMUEBERW_RL_BL_2_L
    *       aktiv                      active
        FEHLERMELDUNG_CC_SL_V_R    CHECK CONTROL (CC) FRONT RIGHT PARKING LIGHT FAILURE
*           aktiv                      active
        FEHLERMELDUNG_CC_SL_V_L    CHECK CONTROL (CC) FRONT LEFT PARKING LIGHT FAILURE
*           aktiv                      active
        FEHLERMELD_CC_RL_BL_2_R
    *       aktiv                      active
        FEHLERMELD_CC_RL_BL_2_L
    *       aktiv                      active
        RL_BL_2_ALS_SL_VORNE
    *       aktiv                      active
        HEIMLEUCHTEN_KL58G         FOLLOW-ME-HOME - INTERIOR LIGHTING
    *       aktiv                      active
        COMFORT_ACCESS_LICHT
*           aktiv                      active
        XENON_WIEDER_ZUEND
*           aktiv                      active
        BI_XENON_VERBAUT           BI-XENON HEADLIGHTS INSTALLED
*           aktiv                      active
        XENON_AL_VERBAUT           XENON LOW BEAMS INSTALLED
*           aktiv                      active
        HERSTELLER_PARAMETER_0
*           wert_02                    value 02
    *       wert_01                    value 01
        QUITT_BLK_ZU_CHECK
*           aktiv                      active
        PWM_ANSTEUERUNG_AL         LOW BEAM PLUG
*           wert_01                    value 01
    *       wert_03                    value 03
        PWM_ANSTEUERUNG_SL_V
*           wert_03                    value 03
    *       wert_04                    value 04
        PWM_ANSTEUERUNG_RL_BL_2
*           wert_02                    value 02
    *       wert_01                    value 01
        DUAL_SP__AL_R
    *       aktiv                      active
        DUAL_SP__AL_L
    *       aktiv                      active
        AL_KL50_SCHUTZ
    *       aktiv                      active
        PWM_ANST_RL_BL_2_AL
*           wert_03                    value 03
    *       wert_02                    value 02
        PWM_ANST_RL_BL_2_FL
*           wert_03                    value 03
    *       wert_02                    value 02
        RL_BL_2_PO_RL_FKT
    *       aktiv                      active
        RL_BL_2_PARKL_FKT
    *       aktiv                      active
        LWR_SCHRITTE_STELLUNG_0
*           wert_01                    value 01
    *       wert_02                    value 02
        LWR_SCHRITTE_STELLUNG_2
*           wert_02                    value 02
    *       wert_03                    value 03
        LWR_ABS_MIN_STELLUNG_2
*           wert_02                    value 02
    *       wert_01                    value 01
        LWR_HYSTERESE_START
*           wert_02                    value 02
    *       wert_01                    value 01
        LWR_VORBESTROMUNG
*           wert_02                    value 02
    *       wert_01                    value 01
        AUSWERT_GRADIENT           TRAILER GRADIENT
*           aktiv                      active
        AUSWERT_PROP_ABWEICHUNG
*           aktiv                      active
        LEUCHTWEITENREG_DYNAM_0E
*           aktiv                      active
        LEUCHTWEITENREG_AUTOM_0E
*           aktiv                      active
        VMIN_BREMSEN
*           wert_02                    value 02
    *       wert_01                    value 01
The car is starting to give me headache...
Old Jul 10, 2011 | 04:16 AM
  #332
Sas's Avatar
Sas
My Ride: 520i ('04)
Originally Posted by bmwfive
I have just been for a 30 min drive and the angel eyes are blinking again. I haven't tried turning off the bulb checks yet, but I managed to get a video of the lights:
...I would like to add that both headlights do in fact blink at different times at similar intervals. (It must have been a coincidence last time as I'm positive they weren't doing this before)
Mine don't blink, i just sat 45 min. staring at the car (i cant seem to get enough).
It's like everyone has his own faults and iDrive errors. It's starts to freak me out...
Old Jul 10, 2011 | 09:18 AM
  #333
bmwfive's Avatar
I have ventilated the housings with holes and painted the chrome with matt black paint. The lights still have the blinking problem after being on for a while, so I took the bulb cover off and felt around the bulb - they barely even feel warm? (it sounds safe to rule out the heat issue)
I have since turned off the cold & warm bulb checks but I haven't had chance to check for the blinking again yet...
Old Jul 10, 2011 | 04:00 PM
  #334
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Strange... will have to think about this one a little more then. I am surprised that a 3W LED is barely warm though.
Sas: I don't have problem with mine
Old Jul 16, 2011 | 07:31 AM
  #335
Sas's Avatar
Sas
My Ride: 520i ('04)
Grrrrr.
Old Jul 16, 2011 | 01:59 PM
  #336
bmwfive's Avatar
I only felt around the 'extra' bit of housing as I couldn't get my fingers to the led itself, so I expect this part was probably warm. I was just expecting the housing to be very hot if it was still trapping heat.
...I've had many occasions to check if they are still blinking after driving, but I keep forgetting lol.
Old Jul 21, 2011 | 12:02 PM
  #337
bmwfive's Avatar
I can confirm that even with the parking light bulb checks off, I still have the blinking leds after a short drive!
It's getting quite boring now. I wonder if the resistor is causing the problem??
I might try removing the resistor completely first as I haven't tried the leds without them yet. I know coding didn't stop the errors with my halogen bulbs, but if it worked on the leds for Sas, maybe it will work for me too. (although I remember Sas had no errors with his halogens to begin with)
...failing that, I could incorporate a relay - mentioned earlier in this thread.
Old Jul 21, 2011 | 02:09 PM
  #338
bmwfive's Avatar
When you add $522 to the VO, did this also stop the errors from the led bulbs - or did you still have to disable bulb checks?
Old Jul 23, 2011 | 11:09 AM
  #339
Sas's Avatar
Sas
My Ride: 520i ('04)
I disabled the bulb checks, otherwise it throws errors for the LED's.
Old Aug 2, 2011 | 12:47 PM
  #340
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
So I just want to chime in and add this. I recently made a conversion cable for Justin (jg525i) and I did the same thing as I had done before and soldered wire 4 and 5 together for the angel eyes. As expected, the cable works flawlessly with stock AE bulb, and no error.
Those that have error should probably just check their wiring.
