Pre LCI Halogen to LCI Halogen conversion
Old Apr 3, 2011 | 02:35 PM
  #271
bmwfive's Avatar
Originally Posted by nomis_nehc
Oh, in that case, I believe this is the list for you:
2x 61136931864
20x 61136901728
2x 61136913653
10x 61138353706
10x 61138364838
20x 61138366245
10x 61138372626
14x 61130007572
2x 61138373573
2x 61138352576
Thats brilliant, thankyou.
I just need to have a good look at the photos and diagrams now to find out exactly how they need wiring.
Old Apr 3, 2011 | 03:15 PM
  #272
bmwfive's Avatar
What actually is the difference between uk and us headlight wiring. (will Sas's photos and diagrams still apply to me?)
Old Apr 3, 2011 | 06:04 PM
  #273
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Well, since you're in UK, Sas's pictures will apply to you. Here in the US, I am assuming it must not be a mandate to require halogen (reflector based) lights to have auto-leveling. Non-US E60's have that little plug, which is what powers auto-leveling, so you guys have a few more wires to make.
I only realized this after I received my parts and was looking at it... and lol'd.
And yes, the pin scheme will apply to you.
Old Apr 3, 2011 | 10:50 PM
  #274
bmwfive's Avatar
Ok thanks for the info, I will get try to get the parts ordered some time this week.
Old May 1, 2011 | 02:47 AM
  #275
bmwfive's Avatar
Originally Posted by Sas
Can somebody explain how this has been modified to fit the lci halogen unit? Has the additional fitting been cut off of an existing holder?
I'm aware that the reason these bulbs don't fit is because they are too long; I have read on another forum that someone has cut the metal bit down to resolve this, but surely this would cause damage to the led.
Old May 23, 2011 | 03:42 PM
  #276
bmwfive's Avatar
Finally got around to making my cables and fitting the headlights.
Did anyone ever get to the bottom of the parking light error? I have read about adding resistors, but it seems people were having problems. The 'dimness' wouldn't bother me if it definately stops the errors, can anyone confirm that this is a working solution. 'livefour2day' had it working but then the errors returned. (not sure if this was due to a bad connection or not?)
If the resistors do work, is it correct that replacing the AE bulbs LEDs will then improve the brightness?
Alternatively, could this be fixed with coding the LCM?
Old May 23, 2011 | 03:56 PM
  #277
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Yes, the answer is resistor. There is only one member that built this harness that I know of that did not require doing extra work and has everything working without error. I don't have the dimness issue since I am running Orions.
Also, coding and disabling cold/warm/iDrive check will not suffice. I've tried it already.
Old May 23, 2011 | 09:05 PM
  #278
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
So what happens when you disable the checks? I was hoping this would solve my issues
Old May 23, 2011 | 09:10 PM
  #279
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Well, actually, thinking back on it, what I said above might be incorrect. My context is a little different since I am not using the stock AE (bulb pulled out). So maybe with coding, it will go away (assuming there's a bulb in there).
Old May 23, 2011 | 10:56 PM
  #280
bmwfive's Avatar
So what happens when you fit LED bulbs?
The only ones I can find are 5w & the original bulb is 10w; will this effect the size of resistor that is needed?
