please help! aftermarket rim question
when I get my 20" rims will I have to put sensors in them? I read the manual and I didn't see anything about any tire pressure sensors, but the sensors that are used sense if you have a flat by measuring rotational speed. is this a sensor installed inside the stock rim that I have to take out and install in my aftermarket rims? or can I get away without installing any sensors in my aftermarket rims?
I believe the sensors being used are the ones for ABS, DTC, etc, to detect differences in the rotationals speed. I have not heard any of the others going to aftermarket rims and needing new sensors. They may have to reset the FTM in idrive though.
Originally Posted by tyronebankz' date='Oct 31 2004, 09:09 PM
need more info, does anyone else with aftermarket rims know if I need to take sensors from stock rims and install them in the aftermarket rims?
[snapback]51542[/snapback]
carid
04-29-2015 04:20 AM
