Part number to audio X13813 M-ASK aux/sub connector plug?
Old Sep 7, 2013 | 12:35 PM
Dieselmotor's Avatar
My Ride: 2004 520i
Default Part number to audio X13813 M-ASK aux/sub connector plug?
Hi!
I recently bought a DIY AUX retrofit kit, but I have one major problem:
I have a E60 without the HiFi-system(live in Norway so this was not standard equipped), so I dont have the connector/plug the aux-cable is supposed to be connected into. Subwoofers is also using the same plug.
The connector is called X13813 as far as I know.
I bought a aux retrofit kit without the plug, and I discovered today that I dont have the connector thing. BMW E60 E63 5 Series 6 Series Aux Auxiliary Cable 65120153502 iPhone iPod | eBay
I have tried to search for the connector part at realoem.com, bmwfans and google with no luck at all.....
Do you guys have any suggestions?
Sorry for my bad English,
Thanks for your good help and time
Best regards,
DieselMotor!
Old Sep 7, 2013 | 05:38 PM
tonyb635's Avatar
Actually I might have one of those. Ill check on Monday when I'm back at be house.
Old Sep 9, 2013 | 01:20 AM
My Ride: 2004 520i
After some research in different forums, both Italian and Spanish BMW forums I finally found the part number for the connector, I think.
Here is the part numbers I need to order from my local BMW parts dealer.
* 61138384550 This is the connector itself. The one number I have been searching for.
* 61138387206
* 61138387204
I will post back here when I get answer from Bavaria Autozentrum
Old Jan 21, 2016 | 11:40 AM
Abuzeeek6's Avatar
My Ride: 530 e60 2003
Hi there,
I have same problem,i miss the X13813 installed in my bmw e60.
Did you solve this problem?
many thanks,
Ziad
Originally Posted by Dieselmotor
Hi!
Best regards,
DieselMotor!
Old Jan 25, 2016 | 10:33 AM
My Ride: 2004 520i
Hi.
Yes I found the right part numbers(the connector is put together by two pieces) for the aux connector:
61138384550
61138387204
Cheers
DavaiLave
Aug 2, 2022 02:16 AM
mrdunu
Jun 15, 2015 03:13 AM
rorschach76
May 30, 2015 06:02 PM
ankurg09
Apr 21, 2015 05:36 AM
BYS2
Mar 24, 2015 03:13 AM
