Opening up e60 headlights?
Watch the video how to open E60 headlights. I got inspired by it and opened headlights successfully.
BMW E60 E61 Scheinwerfer öffnen open headlights - YouTube
My Ride: 530i base model
I've done this before but not to E60 headlights, I guess it could be done, I like how clean it comes off.
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
Yes, I was applying heat and then very hard pry polycarbonate part out (i needed to use much force to open it). After opening, the flange on black plastic could be damaged so I repaired it and cleaned the flange from old sealant (it was hard work to remove the sealant).
Everything is sealed properly, I tested it with air pressure with blocked breather elbows.
I just simply filled groove around housing (whole old sealant removed) with silicone to about 2/3 of height, pushed transparent plastic part into the groove and wiped out silicone from outer side with wet finger.
