Ok im on a roll, project no.2
Just got a great deal on a USB audio (SA6FL) retrofit kit and a ULF2 high on eBay, cost £168. This kit brand new retails in excess of £450 plus coding.
Pics when the kit arrives.
This means I will be putting back my CD-changer and selling my iPod interface and specdock.
My Ride: ///M5 BEAST
is there anyway i can get an aux in or ipod functionality on my CIC w/o dropping a thousand damn dollars on the combox? can i go the same route you just did? can i simply use your ipod interface? (if so ill buy it lol) thanks and good luck w/ the new project!
I do believe the iPod interface will work with the CIC.
My Ride: E39 M5, E60 M5 and F06 M6GC
Model Year: 2000/2006/2016
BLooD is absolutely right, IPod interface works just fine with the CIC. In fact, if anything it works more smoothly now than it did with the old CCC.
Hi
Sorry to hear . hope nobody was heart.
After I now have mounted the CIC controller with my LCI-CCC , and at that time did do an oprade of the SW in the CGATE modul af the CCC , I'll try and mount the ULF2 once again to see if that have changede anything , I'm pretty sure that one of the modul's in the CCC have the "answer"
, due to it is the CCC that controls/create the MOST-ring signal , and controls the components on it ( wake them up ,transport sound , etc. ) , and due to the fact that the ULF2 is MOST-ring controlled it will aslo need it's "wake up call" from the CCC.( what it not get's at the moment
Due to I already drive with the LCI-CCC it should be "new" enough to controle the ULF2 , and work "together" with it ( ULF2 and LCI-CCC came i E60&61 prod. after 03/2007 ) , so I'm convinced it is a "simple" coding matter/question
Hi
BenAnd
)Due to I already drive with the LCI-CCC it should be "new" enough to controle the ULF2 , and work "together" with it ( ULF2 and LCI-CCC came i E60&61 prod. after 03/2007 ) , so I'm convinced it is a "simple" coding matter/question
Hi
BenAnd
Hi
Hi
BenAnd
Hi
BenAnd
bmwgroup
Oct 18, 2015 07:01 AM
PelicanParts.com
Meet & Greet Discussion
Oct 16, 2015 03:07 PM
ucsbwsr
Sep 19, 2015 10:58 AM
