New water pump defective?
My Ride: BMW 528i
Just received a new Pierburg electric water pump 11517586925. Opened the box, took the pump out of plastic bag and found the pump house seam was wet looking like leaking.
Is the pump like that ok?
My Ride: BMW 528i
The sell sent me another one which has the same issue. And said that was moisture
I really want to know It is OK like that and don't need to waite for another shipping.
My Ride: BMW 528i
The new pump and thermostat were installed, but no bleeding process activated - Press start button without brake, highest temp, lowest speed fan, then step gas pedal to the floor for 10 minutes.
The pump connector gounds good, Name the pump connector ground 4., each pin to ground as blow.
Ignition OFF, only pin 1 = 12v
Ignition on, Engine off, pin 1 = 11.9v, pin 2 = 0.07v, pin 3 = 7.64v
Glove Box and Trunk fuse box, all fuse are good.
My 2010 528i had fc 2E81 and 2E82, that is reason water pump and thermostat were replaced.
My Ride: BMW 528i
I unpluged the water pump, then checked voltage on the connetor.
My multimeter negative probe on pin hole 4 while checking other pin hole voltage. Pin hole 4 got 0.06v means my system has problem?
Thanks!
Thanks!
My Ride: BMW 528i
The water pump has been using for 1 month and running ok.
The first coolant bleeding process started since I dailed the fan to lowest speed and the temp to highest level between turnig on the access power and steping on the gas pedal. Presetting lowest speed fan and highest temp did not work at that time
Yesterday, presetting fan speed and highest temp works too.
Happy DIY
Happy DIY
My Ride: m5
Model Year: 2009
Engine: 3500
The rise of AI technology has led to the automation of work, marking the new-age business revolution https://mlsdev.com/services/mobile-app-development. Right from robots working in factories to automated hotel bookings, the theme remains constant with the only difference being - where exactly AI works. With a growing trend in the automation of routine work, AI is quickly automating several routine business processes. After all, which business owner would not want technology that forgoes coffee, lunch, and smoke breaks?
