Need Launch backup file for E60 mirror folding retrofit
Old Apr 7, 2026 | 08:23 AM
Konhrb's Avatar
Probation Members
Default Need Launch backup file for E60 mirror folding retrofit
Hi everyone,I’m working on a retrofit for BMW E60 power folding mirrors, and I’m currently stuck at the coding stage.Here’s my situation:Car: BMW E60Retrofit: Installed power folding mirrorsTool used: Launch (X431)Module: FRM / GM (checked both)I managed to:Access coding optionsEnable some features like windows / wipersBut:❌ I cannot find mirror folding option in Launch❌ Or maybe it exists under another nameI also tried:Backup coding from Launch (TXT file)But I don’t know how to read/edit it
Files : cas and kbm
File Type: txt
EOld_KBM.txt (171 Bytes, 15 views)
File Type: txt
EOld_CAS.txt (323 Bytes, 16 views)
Old Apr 7, 2026 | 08:36 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You need to fill out year and model in your profile so we know what you're working on. Kind of hard to guide you with no info. Also if you're using a scanner to code you're already behind the curve of what you need to retrofit.
Corellian Corvette
Apr 5, 2021 10:58 AM
eMathewJose
Dec 5, 2013 08:07 AM
sd_dracula
Apr 2, 2011 12:43 AM
Mach_666
Mar 19, 2008 11:46 AM
the chang
Sep 13, 2007 08:29 AM
