need help on muffler
Old 12-23-2008, 01:57 PM
Originally Posted by suthurnbimmur' post='751204' date='Dec 23 2008, 05:58 AM
Thanks NerWeezy!! Def good Ideas............About taking out the resonator, would the sound be too loud? I just to enhance the sound and still look like a Luxury Sports car, ya know. I think I might go with just changing out the muffler and if I still want it louder, will remove the resonator.
What about the Vac Line that Ktlocklear is talking about, is that gonna be an issue? What do you do with that line? Thanks again guys......
removing the resonator will deepen the sound, but some reported before that removing the resonator with the stock exhaust/muffler will have no / not much effect. Id say do the muffler, then if you want more sound out of it take out resonator and replace it with straight piping. thats the route I took before as well
Old 12-23-2008, 02:00 PM
Originally Posted by bespoke1' post='751206' date='Dec 23 2008, 06:01 AM
I'm considering Magnaflow as well. What is the difference between the 14862 and the 14816??
main difference are the tips. the 14816 has 3.5" round tips and the 14862 has 3" round tips. I think the 14862's tips may be a little angled as well now that I look at it.
Old 12-23-2008, 02:50 PM
TAJARO's Avatar
My Ride: 2007 550i, Mystic Blue over Auburn, 6-Manual, Sports, Premium, Cold Weather, Logic 7, Nav, Sirius, MTec Front & Sides with M5 rear apron, VIS Penta carbon fiber vented hood, OEM M166s, (or Style 101M with winter 19 Blizzaks), BMW Blue Calipers, Custom Quad Exhaust and M5 side grills, trunk finisher and spoiler. Rogue Octane SSK/WSR and Zeckhausen CDV, BMW illuminated shift knob, Delivered 4/26/06 - Ordered 3/18/06 from Otto's (the Best) BMW Dealership.
Originally Posted by TAJARO' post='751345' date='Dec 23 2008, 12:30 PM
The vac line just opens the other side of the muffler at certain RPM. Below that point it's to create more bck pressure which some think helps torque and/or scavenging for fuel economy and emissions. Just unplug it, block the line and it's fine- no codes thrown and I've been in to the dealer for service with no comments/issues.
Sorry- wasn't clear in my note. If you are going to leave the stock muffler on, either weld the valve open or leave it alone... My advice above is only relevant if you are replacing the stock muffler... Before I did change I did lock the valve open but I don't notice any change at all on performance. I'd bet it's an emissions relevant item but who knows- the BMW dudes love to make it more complciated than it really needs to be.
Old 12-23-2008, 05:29 PM
suthurnbimmur's Avatar
My Ride: 2004 BMW 545i
Lots of great inputs fellas!! I really appreciate all your opinions. I think I will replace it with 14816 and maybe do the resonator at a later date.
To confirm, leave the valve open or close when I do the change? Thanks again.....
Ricracing, awesome diagram, helped me understand how that thang is hooked up.....thanks again
Old 12-23-2008, 08:56 PM
Bimmer32's Avatar
The butterfly valve is for more exhaust flow at higher rpm, usually above 2500 rpm. It does not necessarily increase sound (may be by 1 or 2 decibels) since the second muffler is quite insulated as the first one.
You should not plug the vaccum. Rather, tuck it away without restricting its flow. When the actuator operates, it just blows air (pressure) out. Quite harmless to leave it unplugged.
Old 12-24-2008, 05:59 AM
545felix's Avatar
My Ride: 05 545/6
how long have you run it this way? I've heard you eventually get a Check Engine light if you don't plug it.
Old 12-24-2008, 06:38 AM
mrfva's Avatar
My Ride: .
Model Year: .
Are you running yours unplugged?
tundra
11-10-2016 06:55 AM
myfiveserie1818
02-20-2016 07:56 PM
EuropeanArtz
09-29-2015 04:26 PM
kcrokin
09-28-2015 08:47 PM
PMorganRacing
E39 Discussion
09-16-2015 04:01 PM
Quick Reply: need help on muffler
