Mounting AMP upside down in TRUNK area?
Old Apr 28, 2011 | 07:28 PM
aresh's Avatar
i want to mount my alpine amp to the trunk roof area, but theres no screw holes or anyway that i could mount it on top. Has anyone done so and how? Any feedback is much appreciated
Old Apr 28, 2011 | 07:39 PM
Georgieb's Avatar
My Ride: 2007 Black Sapphire 535i
I've been thinking about where to discretely mount an Amp in my trunk also. Have you considered hiding it over your rear driver-side wheel-well? Here's what another member did, he built a platform above the wheel-well, and used brackets to hold the Amp in place. Then swapped out his wheel-well boot trim for one used in cars with the DVD changer (BMW part # 51477122193) plus he added the oddment tray (BMW part #51477074479). This one sits higher and covers the Amp completely.
Check out some pics here. Scroll down to the #12th post.
https://5series.net/forums/topic/477...plug-and-play/
Old Apr 28, 2011 | 07:53 PM
aresh's Avatar
yea i already have an amo there to drive the woofers under my seats, so that option is off the list, i want to mount it on the roof of the trunk, I've seen people do it, but i just dont know how to on our cars. Im sure theres a way, maybe some kinda bracket that glues on and then you can mount the amp onto that? Just need some direction, i will probably hit up home depot to see whats available.
Old Apr 28, 2011 | 08:09 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Usually amps don't like to be installed upside down because of how they are thought to be cooled. The cover works as a radiator and it is often profiled to get some more surface for heat to dissipate. If the amp is upside down the dissipated heat will stay over the amp instead of moving away from it. I'm sure there are exceptions in amps too.
- Antti -
Old Apr 28, 2011 | 08:20 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
self tapping screws??
aresh's Avatar
drill into the metal?
Old Apr 28, 2011 | 10:50 PM
Anzafin's Avatar
- Antti -
Dissipate = Evaporate
Old Apr 29, 2011 | 02:49 AM
196ski's Avatar
My Ride: 2008 535xi V1 hardwire Laser Interceptor 12" JL Audio Ported PowerWedge enclosure with one W1v2 20% tint
if you have a digital amp, like an alpine PDX you can mount it updisde down as they are so effecient that they don't get hot. If you have a conventional amp, the heat sinks won't much like being upsidedown.
self tapping screws aren't a good options as they may come through the rear deck. I'm not really sure of the claerance though, so it might work? If that won't work, you can tack weld some custom brackets in place, or take the rear deck off from inside the car, and use through-bolts with custom brackets.
Old Apr 29, 2011 | 04:12 AM
Georgieb's Avatar
If you have sufficient surface area, 3M Dual Lock may be another option. This is among the best adhesive/lock type material used in the auto industry today. Here in Canada one of the applications is to hold panels in place on public transit buses. Tensile strength is awesome. Depending on the weight of the Amp, the amount of usable surface area for this material is important.
Just a thought....
http://www.3m.com/product/informatio...-Fastener.html
http://cgi.ebay.com/NEW-3M-Dual-Lock-Reclosable-Fastener-System-MP3560-/150595624342?pt=LH_DefaultDomain_0&hash=item231032dd96
Attached Thumbnails Mounting AMP upside down in TRUNK area?-3m_dual_lock.jpg
Old Apr 29, 2011 | 04:23 AM
aresh's Avatar
wow this is excellent, thanks alot
MartinF
May 22, 2015 12:17 AM
tex_phil
May 21, 2015 01:57 PM
incoherent
Apr 15, 2015 04:48 PM
mrbelk
Oct 29, 2003 10:08 AM
