M5 Rims/Tires
Old Nov 10, 2007 | 12:35 AM
marathonchief's Avatar
I bought a set of M5 rims and tires from a vendor in NJ who swore the tires (Front 255 40 ZR19) and (Rear 285 35 ZR19) would fit a 2007 530i sport suspension with no problem. Well this individual is wrong. The front wheels hit the struts and the rears :thumbsdown: come very close to the body. So, I guess what I am asking from the individuals who are using M5 rims, what size tires should I mount on them.
Old Nov 10, 2007 | 03:44 AM
5er Sport's Avatar
to the best forum ever!
You should use the following sizes 245/35/19 in the front and 275/30/19 in the rear.
Old Nov 10, 2007 | 05:20 AM
Heelsonwheels's Avatar
so are you going to try spacers? post some pics if you can of the rear.
Old Nov 10, 2007 | 01:54 PM
EBMCS03's Avatar
5er Sport is correct with the tire sizes. The tires on the M5 is too wide for the regular E60. The rims work fine... just not the tires...
if you REALLY wanted to save money you can leave the rears alone they fit w/out problems, just change the front tires, like you said.. its just close. theres no problems. The only little niche about that is with 245/35/19 fronts your fronts will spin a little faster than the rears.
sfcacique
Apr 22, 2013 07:33 AM
rojames
Apr 3, 2013 04:35 PM
BillMcC
Jun 1, 2010 05:58 PM
psE60
Mar 15, 2009 03:13 PM
Hobart
Aug 27, 2005 07:22 AM
