M sport steering wheel retrofit
My Ride: Retired 2008 535i Titanium-silver with sport, premium, steptronic, NAV, HUD
Retired 2006 525i
Hi
How much does a M sport steering wheel retrofit cost.
When they re-fit the airbag, is it as safe as a factory fitted airbag.
I have a 2006 non-sport 525i, automatic, will those smg paddles be of any use to me?
Thank you all in advance.
If you just want M sport steering wheel without paddles, all you need are
1. M-sport steering wheel
2. New multifunction buttons
3. New sport round airbag
4. New airbag mounting plate
If you need M5 steering wheel with functional paddles, you'll need the following items in addition to the above
1. M5 or non-M5 paddle shifter
2. M5 SMG steerning wheel instead of M-sport steering wheel which does not have pre-cut slots on the side for paddle mount
3. my530i's paddle shift kit
The paddle shifter works whenever you switch to manual mode, and you can shift up and down with either paddle or lever shifter.
If you're interested, please let me know.
Best regards,
my530i
Best regards,
my530i
Best regards,
my530i
Best regards,
my530i
My kit only works on Steptronic.
For SMG, we only need a set of wiring harness to make it work with M5 paddle shifter.
I have develop the following combinations:
1. M5 Paddle Shifter for pre-09/05 car build with Steptronics
2. M5 Paddle Shifter for post-09/05 car build with Steptronics
3. Non-M5 Paddle Shifter (regular SMG push/pull paddles) for pre-09/05 car build with Steptronics
4. Non-M5 Paddle Shifter (regular SMG push/pull paddles) for post-09/05 car build with Steptronics
M5 paddle + and - sign lights up brightly at night when headlights are on.
I also have M5 shift knob which shows correct gear status for R, N and D/S for Steptronics. The kit can be only plug-and-play wiring harness or with M5 knob or complete plug-and-play kit including M5 knob, modified boot, and wiring harness.
I'm opened to group buy if anyone interested.
Thanks
Thanks
