JB3 and turbo tuner question
Old Apr 23, 2010 | 12:05 PM
Eugene134's Avatar
My Ride: F10 535I
Model Year: 2016
Dont kill me or tell me to use the search function..
Have a question I've been looking into getting the plug and play JB3 and then I also saw a split second turbo tuner. If I get the JB3 then the turbo tuner is not needed as it seems that the JB3 gives all the same things and then some?
Would appreciate any help
thanks
Old Apr 23, 2010 | 12:13 PM
Gene's Avatar
correct, it's not needed/recc'd to stack the SSTT (tmap tune) on top of the jb3 (ecu tune).
some members on e90posts have stacked a tmap tune (jb+) on top of an ecu flash (dinan, maybe giac), but even that is not recc'd and requires individualized programming from BMS....
just go with the jb3 as it will have more controls over the timing and pressures and less likely to throw tuner/manip codes, and as you stated, has the same features as the sstt and then some
vards01
Jul 11, 2015 11:53 AM
star69me
Jun 17, 2015 07:40 PM
windnsea
May 25, 2015 09:49 PM
Mikethepanel
Apr 25, 2015 02:33 AM
brian1225
Apr 16, 2004 05:59 AM
