Hub Ring Size
Old Jul 20, 2010 | 06:06 PM
gurp99's Avatar
My Ride: BMW e60
Hello,
I got the replica M6 rims and I was advised I need to install hub rings. I have no real vibration issues but do feel it over cracks and bumps in the road. Will 72.6mm TO 74.1mm HUB CENTRIC RINGS provide a better ride?
Let me know
thanks
Old Jul 20, 2010 | 09:15 PM
tooltec's Avatar
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
If your replicas have a 74.1mm centre bore (so they will fit the E39) you must fit 74.1 - 72.6 spigot rings in order to centralise the rims on the hubs.Cheap ones are plastic and cannot be recommended,get the better quality aluminium ones.
Advice for others thinking of buying replicas - choose a make with a 72.6mm centre bore.One example is WSP Italy who use the flow forming technique in manufacture.
Old Jul 21, 2010 | 07:50 AM
gurp99's Avatar
My Ride: BMW e60
thank you very much! ill look into the aluminium rings today
Old Jul 21, 2010 | 07:58 AM
monsterj34's Avatar
well there are con and pro on both plastic and aluminum ones as my friends told me before.
i tried both and plastic one had less vibration than the aluminum one.. also aluminum can be damaged or bent easily...
Old Jul 21, 2010 | 10:36 AM
tooltec's Avatar
Another reason to buy rims with the correct centre bore in the first place!
E60Japanese
Jan 20, 2025 04:23 PM
E60Japanese
May 27, 2015 03:25 PM
G530
May 15, 2015 10:42 AM
asinner
May 6, 2015 06:03 PM
E60Japanese
Mar 23, 2015 05:23 PM
