Fitting heated rear seats
This brutal winter is making me want heated rear seats for my passengers! My car already has the cold weather package and comes with heated front seats what can I do to get heated rear seats? Is it true if my car is already fitted for the heated front seats the rear should already have all the "guts" and all I need is the switches?
Wasn't there a thread on this recently?
Essentially, the heaters are these thin'ish pads that fit between the padding and the leather. The way to install them is to remove the rear seat bench and seat back, take off the upholstery. Install the heating pads. You'll need to run power and controls to them - that's probably a little tricky. But if you've ever done a stereo install, or smth like it, you should be just fine.
My Ride: 2006 550i - Sport package, Cold Weather package, Nav, Xenon lights, 6 speed manual
Mods coming soon...Still need to figure it out.
Yes...there is a very detailed DIY recently from gentleman in Indiana. He did a great job with it. Let's see if I can find it
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
Engine: N54
socale39
09-05-2023 08:30 AM
TexaZ3
05-06-2015 09:54 AM
