E60 Stereo Upgrade
Old Nov 22, 2007 | 01:24 PM
thedreamshop's Avatar
My Ride: 2004 545i titanium grey 6 speed manual with light grey interior. Nav, L7, cold weather, sport, sat. Modifications: suede headliner, pianno black interior trim, Ipod dock, Mtech front bumper, Angel Eyes, and flat black kidney grills.
Originally Posted by Black BMW530iA' post='497686' date='Nov 22 2007, 02:58 AM
Is there no one who can tell how to install an extra amplifier???
Do the headunit have normal low-level line out or is it some
BMW specific?
Is it posible to use the line out from the original amp?
Anyone???
The Logic 7 system uses optical lines to send the audio to the nine channel L7 amp. All outputs are crossed over/equalized based on volume and speed. If you want use an aftermarket amp you would need to use an 8 channel signal summing devise and EQ such as the Audio Control DQL8 or JBL's version of that product. For anyone with the HI-Fi system the radio has four speaker level outputs that could be used as an RCA but would likely need a line out converter to get the signal level down to the amps recommended input voltage. The Hi-Fi system has an amp but just for the subwoofers so the radio wires would be your front and rear and the sub signal would be from the amp output. A EQ/Sum devise still would help but is not as crucial as with the L7 system.
Old Nov 22, 2007 | 01:37 PM
Black BMW530iA's Avatar
Thank you
Old Dec 19, 2007 | 02:23 PM
mk23169's Avatar
Originally Posted by Black BMW530iA' post='497897' date='Nov 22 2007, 05:37 PM
Thank you
Sorry, Ive been away.... To install the amp you need to find which outputs on the stock amp are for the subwoofer and then you take a line out converter and connect it to the new amp. This way, your on screen eq still works. If you need help p.m me.
Thanks
Mike
Old Dec 19, 2007 | 02:32 PM
Shamu's Avatar
mk23169, you have PM
Old Dec 21, 2007 | 04:49 AM
raleigh29's Avatar
Thanks
Mike
Can you post some detailed Pics of your setup please?
sfcacique
Aug 25, 2025 06:56 AM
addy33
Apr 13, 2015 04:40 AM
rackhacker9275
Apr 7, 2015 12:31 PM
rackhacker9275
Apr 6, 2015 04:55 AM
ZeZe
Oct 15, 2003 12:58 PM
