E60 LCI Trim Removal?
My Ride: 550i E60 Alpine White
Hello,
I don't see many videos or DIYs for LCI trims. My belief is that LCI trims are significantly different from those pre-LCI for E60 (they even look different) and I've having a really hard time figuring out how to remove them.
Thank you
Thank you
All the "wooden" trims including the dash, the doors, the shifter and the nav trims. I believe it's a total of 9 pieces. I was originally thinking about buying new trim pieces, or getting some M5 used ones or even wrapping them. Mostly to change up the look. The ebay ones all look "used."
Ideally i'd love to get my hands on some piano black individual trims.
My Ride: 530ix
Model Year: 2020
do a search, the interior is easy to dissemble with the right tools, esp the nylon pry pars that do not hurt your dash. many with pictures. Search for CIC retrofit. that shows alot of places that show you how.
The doors are the toughest as you have to remove the door panels to get to the back pressure rings that hold the back pieces of the door trim. However you cannot remove the door panels fully from the car because of the airbags connected into the door panel itself. There is enough slack to put them down on a baby stroller or something like that (open door and just lay the panel on the stroller), so you have a surface to work on and there is no stress on the airbag cables. I wrapped mine, liked the look and then replaced them all with aluminum from an M5. looks awesome, i just with i could put lighting in them like the newer F10s....
My Ride: 530ix
Model Year: 2020
to pull the tension clips off that hold the door trim to the panel, use some sort of u shaped hook to pull up form underneath to bend them backwards. then when you pull enough off, you can just remove the washer and use pliers to flatten back out. It will make sense when you see it.
When I was searching for trims on ebay it seems that many of them have broken "clips" on the door trim pieces. Are those repairable? One seller said that if I want to install these door trims I will have to use glue which I don't want to because then I would have a hard time to remove them again. I couldn't find the part on the door panels on realoem.com so I'm assuming these are unrepairable once the clips were broken off. I haven't seen them in person so I'm not sure but if you did, please let me know whether these broken "tabs" or "clips" on the door panels are repairable or not.
Thanks
Thanks
My Ride: 530ix
Model Year: 2020
Thanks
Thanks
YannickVT
10-23-2014 09:52 AM
