Diversity antenna question
My Ride: 2005 BMW 525D M-SPORT // Grey // SB attached
hi all,
I have a 2005 525d sport. The locking distance is very poor now and radio signal is poor too. I have figured out I need to get a diversity antenna but apparently there are different flavours.
Can someone please confirm which exact part I will need?
Thanks!!
Thanks!!
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
With the options list below the image on REALOEM you should be able to figure out which one you need. Most of these are excluded by date, for others you may have to verify the frequency listed which seems to be associated with the options mentioned above the list.
Be sure to enter your vehicle date and/or VIN instead of using my link right away since I just entered a random 09/2005 build.
In case you're not sure after all just give your VIN to the parts dept. at your dealer and they'll come up with a partno. If it isn't compatible it's their fault...
This is my car
http://www.realoem.com/bmw/showparts...24&hg=65&fg=30
still cant work out which antenna I need though :/ Doesnt have a TV function
Edit: Think it's one of these
01 Antenna amplifier Diversity 315MHZ 1 65209193836 $197.28
01 Antenna amplifier Diversity 868MHZ 1 65209193832 $197.28
Dont know if mines a 315MhZ or 868 Mhz though ...
Hello Nudda,
The frequency is imprinted on the back of your keys (at least that's been the case with all my sets).
Any luck?
Any luck?
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
before you change your's you may want to just remove it and clean the contacts.
thanks all.
Nothing behind my key.
Will try removing and cleaning before though
Aprpecaite it!
Aprpecaite it!
aqualibrium
07-21-2015 03:11 AM
