hi all,
I have a 2005 525d sport. The locking distance is very poor now and radio signal is poor too. I have figured out I need to get a diversity antenna but apparently there are different flavours. Can someone please confirm which exact part I will need? Thanks!! |
With the options list below the image on REALOEM you should be able to figure out which one you need. Most of these are excluded by date, for others you may have to verify the frequency listed which seems to be associated with the options mentioned above the list.
Be sure to enter your vehicle date and/or VIN instead of using my link right away since I just entered a random 09/2005 build. In case you're not sure after all just give your VIN to the parts dept. at your dealer and they'll come up with a partno. If it isn't compatible it's their fault... |
Thanks Theo!
This is my car
http://www.realoem.com/bmw/showparts...24&hg=65&fg=30 still cant work out which antenna I need though :/ Doesnt have a TV function Edit: Think it's one of these 01 Antenna amplifier Diversity 315MHZ 1 65209193836 $197.28 01 Antenna amplifier Diversity 868MHZ 1 65209193832 $197.28 Dont know if mines a 315MhZ or 868 Mhz though ... |
Hello Nudda,
The frequency is imprinted on the back of your keys (at least that's been the case with all my sets). Any luck? |
Originally Posted by Theo
(Post 1431569)
Hello Nudda,
before you change your's you may want to just remove it and clean the contacts.
thanks all.
Nothing behind my key. Will try removing and cleaning before though Aprpecaite it! |
