Coded some extra menu options.
Old 01-23-2011, 11:00 AM
  #141
andy545's Avatar
Model Year: 2005
Engine: 545i
Originally Posted by jay77
this sounds like there is another module that needs coding, as I get the same when I try and enable welcome lights, the option in idrive unticks its self as it cant find the instructions in the LMA (mine is an older module), you may need to update your HUD module firmware or module if an option is missing... may be worth checking the module versions as well..
That's exactly the direction I need to take - I should not only compare module trace files but also version with those who MHUD works.
Doed anyone know if WinKFP can update an individual module's software version ?
Old 01-23-2011, 11:23 AM
  #142
BLooD's Avatar
WinKFP can update inidviual modules, I have updated my car to ISTA v39 this way.
Old 01-23-2011, 11:44 AM
  #143
andy545's Avatar
Model Year: 2005
Engine: 545i
Blood, you keep on giving the right answers mate !
now, how do I learn to use WinKFP
Old 01-23-2011, 11:45 AM
  #144
BLooD's Avatar
PM me an email and I will send you a pictorial DIY.
Old 01-23-2011, 11:56 AM
  #145
madein's Avatar
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
I sent one as well
Old 01-23-2011, 01:41 PM
  #146
NoQuarter's Avatar
Engine: N54
Just to be clear on a couple things:
- I do not have an M cluster but my M view Hud works in my '07 and '08
- I did make changes in both modules CAPPL and LM2 just as shown in the coding testing results thread
Here are the ORIGINAL files. The changes I made are documented in the NCS Expert Code Mods test results thread. (I don't have a copy of the modified files)
Be sure to contribute to the summary of changes that you are able to validate
http://forums.5serie...pert-code-mods/
-Jim
File Type: txt
File Type: txt
Old 01-23-2011, 02:25 PM
  #147
andy545's Avatar
Model Year: 2005
Engine: 545i
Check - thanks.
-Jim
Thanks Jim, I'll be populating that excellent thread with some testing I've done. I think it's a good place for validated work.
..and, yeah was always clear regarding your first point you make. Please clarify the second point though- are the changes you made in the CAPPL and LM2 relating to the Mview in the HUD ? or is this just a general remark. Unfortunately I can't correlate anything from that thread relating to the Mview in our HUD to the original files. There is also no mention of the HUD module in that thread which is necessary for Mview. I'm sure I'm missing something here.
My question in essence is:
Is the HUD module the only thing you manipulated to achieve the Mview on your car ?
thanks,
andy
Old 01-23-2011, 03:11 PM
  #148
NoQuarter's Avatar
Engine: N54
Check - thanks.
thanks,
andy
Sorry 'bout that - I had welcome lights in my head.
For Mview I needed to change CAPPL and HUD modules.
Here is my ORIGINAL HUD file.
And I attached my notes where I kept track of my changes and other things I tried. The HUD entries in there are accurate to my current settings.
File Type: txt
File Type: txt
Old 01-24-2011, 02:11 AM
  #149
andy545's Avatar
Model Year: 2005
Engine: 545i
thanks
Old 01-24-2011, 06:57 AM
  #150
Ehssan's Avatar
My Ride: Many BMW's
Blood : I would love to know please ,, I will PM u an email if you don't mind
Quick Reply: Coded some extra menu options.
