Clunking Sound over Bumps :(
Old May 5, 2011 | 08:15 AM
  #21
525iEnjoy's Avatar
Pm'd you, Also on the rod you'll need a torx bit to hold the rod in place while you spin the nut...now with an impact gun you'll wont need to do that cause it spins it faster makes sense right. Same with swaybar endlinks you need that torx bit to hold the rod so you can break the nuts loose with a wrench. its exactly like the rear swaybar endlinks.
Old May 5, 2011 | 02:30 PM
  #22
inktoxicated's Avatar
My Ride: 2006 530i mystic blue
yea when u try to tighten the nut the shaft will spin with it so take a torx or allen key stick it in the stop then put a box wrench over it and muscle it in opposite directions. ifur coilovers dont have a adjuster hex on top then use the impact gun
Old May 7, 2011 | 12:43 PM
  #23
TheRacerBoss's Avatar
My Ride: Bmw
Tried everything guys,
Nothing helped -- I have an appointment with a specialist next week.
Old May 7, 2011 | 10:24 PM
  #24
Dutch 530i's Avatar
Originally Posted by TheRacerBoss
So what exactly was the problem ?/
The front mounts ??
It was the bump stops that cured the banging. Then I changed to H&R race so because I went lower I decided to get new top mounts just incase they were starting to wear. There's been no clunking since then. Strange as most advise against the H&R race but I've found they match better to the Koni yellow's and look a damn site lower at the back:-)
I'm sure if you haven't put back the bump stops (shorten them a bit though) then your problem should go.
Old May 8, 2011 | 06:41 PM
  #25
v_therussian's Avatar
Did you change spring guides when you had the new springs put in? I have some very moderate clunking after I had the new suspension put in, and it is probably because of the old spring guides. I'm going to get the new ones installed (hopefully, soon), so I'll let you know if it fixes the problem. But if you're using your old ones, chances are, they clunk.
Old May 9, 2011 | 10:06 AM
  #26
My Ride: Bmw
What exactly do you mean by old spring guides ?
Old May 18, 2011 | 05:41 AM
  #27
My Ride: Bmw
Clunking reduced dramaticly after springs settled but its not completely gone, taking the car to a the shop
Old May 18, 2011 | 09:24 PM
  #28
G530's Avatar
Could be part of the new spring seating that need to settle in. My CO's clunked for a while that drove me nuts like you. After 3 - 4 weeks, settled in and dont even know if noise is there anymore.
Old May 18, 2011 | 09:28 PM
  #29
tex_phil's Avatar
My Ride: 04 525i, 04 Dinan M3
Yep, I've had alot of improvement in just 1 week of coilovers settling, ride is MUCH better
Old May 18, 2011 | 10:25 PM
  #30
When I had my suspension installed, I too got some clunking. I am now trying to work it out with my shop. Actually, had the car lifted today and the clunking got much better after the car was dropped back. Nothing was really done, except a tightening of the bolt in the lower damper bracket.
By guides, I meant the upper and lower spring pads (items 9&12, below; I still like the term "guide" better ). I just bought them yesterday, want to get them installed asap and give the entire suspension a re-torquing with a proper torque wrench...
Clunking Sound over Bumps :(-fmounts.png
Sou1b1azer
Oct 14, 2015 06:55 PM
bmwmonkey
Aug 17, 2015 10:34 AM
OldSpool87
Jul 26, 2015 02:23 AM
ripley
DIY: Do It Yourself
Jul 12, 2015 01:49 PM
lukieno1
Jul 1, 2015 04:37 PM
