CIC Retrofit Installation LOG
#501
My Ride: BMW E61 535dA M Packet & Yamaha R1 2007
Hi! Please , help me...I have a BMW E61 535d , without navigation , but with Logic 7 and CDC and i want to make retrofit with new CCC navigation , with new controller. I have all pieces , CID , CCC module and new controller , i put all togheter in my car , i added $609 in VO in CAS and LMA , i followed all steps form internet , but when i code my car , i get this error...please , i have few questions: when i make re-code with NCS Expert , do i need internet connection? Do i need to remove the old controller forever , before install the new one ?
#502
I should be able to send those pins and connectors to you next week. If anyone else wants to add new screen and controller connectors in parallel with the old ones for easier swapping of the CIC and CCC please shoot me an email.
I guess Ehssan should be the first one to try it for us as he received his CIC kit already
#503
Ive been lurking on this forum for quite a while now and with the help of Patryk managed to get CIC installed in my 2008 LCI E60.
The car is not coded yet but everything is working OK except the LEDs on the touchbuttons (on the CIC itself) are not lighting up.
Any ideas?
Any ideas?
#504
Any ideas?
Any ideas?
#505
Help!
I have purchased all parts required , cic, hd screen, controller and cabling ,trim etc.
And when I install them into my 2005 e60 with old ccc and voice control, HUD etc
Everything seems fine, picture and sound but car will not start just makes juddering noise.
Car is not coded yet as I am saving up for this but would of thought there would be other issues like the ones
Mentioned on this great thread .
Has anyone else had these problems or know of a solution till I get coding done.
Sorry if this is stating the obvious....have you flattened the battery!?!?
#506
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
#507
hopefully i will start my installation next weekend as the car at the dealer now for few stuff to be fixed ,,
will post a few pictures for the installation specially the parallel CCC/CIC I-drive controller - the pre-LCI/LCI climate control and the CCC/CIC screen ,,,
I was told by the service advisor at the dealer today that if my car went for any job at the dealer with the CIC installed , immediately I will loose my warranty ,, so the swap is a must for me ,,,
#508
That's interesting. I know a few people taking their cars to US dealers with the CIC without any issues.
Your dealership might not understand it is 100% OEM modification, but it's better to do what they want just to be safe
#509
Thanks Patryk, this will make things easier for me. I too have extended warranty and do not want to loose that.
#510
Having stuck with it i managed to get car starting.
What was happening was car would not start but sat nav seemed to be working fine,
Then after a while sat nav was Trying to boot up and car started fine.
So now I have no nav or phone not dialing out, but I guess this is coding issue.
