CIC Retrofit Installation LOG
Old 03-19-2016, 10:18 AM
  #1041
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Can anyone help with cic controller how do i make it work on ccc ?
I try coding
(ZBE - IDRIVE CONTROLLER ( ZBE ) TYPE
HIGH
Old 03-21-2016, 05:29 AM
  #1042
maron's Avatar
My Ride: 525i
ZBE> low_with_slopes
CGATE> program > 9185636
Old 03-22-2016, 06:50 PM
  #1043
funglenn's Avatar
My Ride: 530ix
Model Year: 2020
Very late to the party. I am looking at doing this retrofit, now that I know I am going to keep the car for another few years (I am going to replace the turbos thus keeping it)
my question. I have a 2009 LCI model.
From the factory I have the LCI Climate control unit and the newer Idrive unit, and the new USB connector in the arm rest with Aux input.
I realize I need the CIC unit itself. However does anyone know if I need a new screen? It seems like if I already have some newer items, perhaps I do not need the monitor. Does anyone have a 2009 that can chime in? This would mean I just need the CIC module and two cables correct?
I can do my own programming--do reazlize I have some but not as much as others who are putting in an LCI Climate unit.
thank you
Old 03-23-2016, 05:36 PM
  #1044
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
This my VIF,
Do u know how long does it take to update that module?
Old 03-23-2016, 09:12 PM
  #1045
maron's Avatar
My Ride: 525i
62:MOSTGW 9185627 → 9185636
DCAN cable about 20-30 minuts
Old 03-24-2016, 03:18 PM
  #1046
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Ok, one more thing.
I just need to update that module nothing else correct ?
Just asking since some modules need to be updated in order.
Old 03-24-2016, 03:33 PM
  #1047
funglenn's Avatar
My Ride: 530ix
Model Year: 2020
is there any one spot that shows what coding is required for the CIC conversion?
Old 03-25-2016, 12:35 AM
  #1048
maron's Avatar
My Ride: 525i
Originally Posted by Kewill0360
Ok, one more thing.
You can update only MOSTGW.
Old 03-25-2016, 04:18 AM
  #1049
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Arigatou gozaimasu.
Old 03-25-2016, 06:23 AM
  #1050
mweine's Avatar
My Ride: 535i Xdrive MSport, Carbon Black/Natural, 6-Speed Man, Dinan stage 2 ECU upgrade
Model Year: 2009
Engine: N54
I have the same issue. The connectors between the CIC and screen are different than the CCC. Therefore a new screen is required. I am still trying to figure out how to install the CIC into my 2009 LCI with the CCC update 2, as I have found that many connectors are different. Any assistance would be welcome.
PS: I was also informed that the HUD from the CCC will not work with a CIC retrofit. Is that correct?
-Mike
thank you
Quick Reply: CIC Retrofit Installation LOG
