AUX Input Install question
Old Feb 25, 2010 | 06:21 PM
D33ZNUT5's Avatar
My Ride: 2006 titanium silver metallic Like new 41k Cold Weather Package
Got my AUX retrofit cable in the mail today and the tag on the cable says E46/39 on it. I was looking at the E60 retrofit install and the parts look the same except for 2 additional twist ties. I'm not 100% certain that the end plug is the same between the two parts however.
Just want to make sure I don't get any surprises when I make my appointment and have all the equipment ready. This cable also has has the mod done to it, do you think the dealer is going to notice or refuse to install since it is modded?
Thanks!
Old Feb 26, 2010 | 03:05 AM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Hi
The AUX retrofit kit is the same for E46/E38/E39/53/ & E60-61 aswell as for the E9x series.
I don't know what "mod" to the cabel you are talking about ?
The car will have to be coded at BMW after mounting the AUX kit , in order to get it work properly ( open for this function in the M-ASK or CCC ), i mean it is code : +KAUX that have to be added to the cars WIN SA/FA list.
/BenAnd
Old Feb 26, 2010 | 04:03 AM
vkhong's Avatar
Model Year: 2010
Auxiliary connector retrofit for external audio sources
BMW 5 Series (E 60, E 61)
BMW 6 Series (E 63, E 64)
Retrofit kit No. 65 12 0 153 502
Instructions --> http://www.navvideo.com/downloads/bmw_auxinput.pdf
BMW 3 Series (E 46), 5 Series (E 39) from 09/2002
X5 (E 53) from 10/2002
Retrofit kit No. 65 12 0 153 502 for the E39 equipped with SA 661+650 BMW Business radio with CD drive
Instructions --> http://www.m3resource.com/downloads/...r_Retrofit.pdf
Make sure you have the right part number for the E60. The wiring harness connector is different.
As for the mod, you can put a heat shrink tubing on it.
Old Feb 26, 2010 | 04:24 AM
D33ZNUT5's Avatar
thanks for the info, now I'm nervous since my cable said e39 on it!
If the parts are different why are the retrofit kit #,s exactly the same?
Old Feb 26, 2010 | 04:31 AM
D33ZNUT5's Avatar
After reading the instructions again it looks like the wires are removed from the existing plug and then plugged into a plug that should already be at the back of the m-ask unit. Fingers crossed!
Old Jun 8, 2010 | 08:37 AM
bat1959's Avatar
Originally Posted by BenAnd
Hi
/BenAnd
Thanks for your very useful input, just what I was looking for. Do you know if the multi CD changer loses it's functionality after the \aux input upgrade?
Old Jun 8, 2010 | 09:27 AM
or_550i's Avatar
This is INCORRECT. The kit will work fine as the wires must be removed to be included into the existing wiring harness.
No change to the CD Changer. Once you get the AUX coded at the dealer you will have the same functions as before with the ADDITION of the "AUX" function.
Old Jun 8, 2010 | 11:49 AM
D33ZNUT5's Avatar
I'm still loving this mod! make sure to remove the resistors on cable before installing so you dont loose base. Internet radio sounds so killer on this!
Old May 13, 2013 | 07:06 AM
F-Tar's Avatar
My Ride: BMW Alpina B5 -05
Could someone tell me if there is resistors in this one?
BMW AUX INPUT ADAPTOR FOR BMW hos mds. No.1 på billjud!
I'm using this cable in my e60, but i'm still feeling that CDs sounds better than AUX :/
Kasmo
May 7, 2019 03:30 AM
Z3r0115
Apr 29, 2015 07:05 PM
5wag
Apr 1, 2015 06:56 PM
Sammie973
Bluetooth & Cell Phone Forum
Mar 12, 2015 06:51 PM
brian1225
Apr 16, 2004 05:59 AM
