545i chip?
My Ride: See Signature
Model Year: 2015
Engine: N55
Are there any chips out there that will increase the hp/acceleration for a 2005 545i? I keep hearing about some vishnu chip but from what I've found out it is only for the 335i... is there anything for the V8 - e60?
Yes. It's not a chip but a flash reprogramming of the ECU. It will cost $400 or more for small gain in HP for non-turbo cars. The turbo cars (535) have the greatest gain. Search this and the performance forums and you will find out what you want to know.
Model Year: 2015
Engine: N55
So pretty much it's a waste to repgram/re-map the ECU unless it's a turbo?
From: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
If you are looking for pure horsepower gains the answer is yes, its a waste of $$. The factory tunes these normally aspirated 8's pretty well out of the chute. The remap usually makes the car a more "driveable" by remapping the power curve so you get more torque earlier in the rev band, removes the speed governor and advances the redline a bit as well. You do pick up some hp that you can feel SOP but nothing dramatic usually 8-10 hp max and that's usually in conjunction with a CAI and larger diameter MAF (a la Dinan).
Turbos in general tend to see significantly more HP gains because remaps get more aggressive on boost vs stock factory settings (more air, more power) as a starting point.
Hope it helps.
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
The more you squeeze out of an engine to more its gonna cost. Do check out that link to the V8 Turbo....but I'll be jealous if you get one
Model Year: 2015
Engine: N55
Hope it helps.
Hope it helps.
Thank you! This was a very thorough and intelligent answer and it gave me the info I needed.
Model Year: 2015
Engine: N55
Originally Posted by miguex' post='667380' date='Sep 11 2008, 06:42 PM
Dude! That SC is bad ass! I've already sent a few questions to that guy and so hopefully it works out... Thank you for the link/response. I appreciate it!
My Ride: 2008 E60 M5/SMG (LCI)
Interlagos Blue/Black Merino
Aux input, sun protection glass, Bluetooth, Voice control
just had the M done .. and again, v small hp gain, but you can really tell the diff.
obviously turbo engines are going to be worth every penny (cent), but wouldn't say that NA wasn't worth it.
EuropeanArtz
Sep 23, 2015 08:21 PM
for John and EuroRev.
