2005 535d Glow Plug socket housing re pin diagram
My Ride: 535d 2005 e60
Can anyone help with the glow plugs to what pin number of the socket housing connector; which plugs go to and which pin. Also need the 3 separate connectors that go to the engine fuse box & dde, as I'm at a loose end locating the wiring diagram that I had and seem to have lost my pictures of the pin layout
engine fuse box/dde
6 glow plugs
engine fuse box/dde
6 glow plugs
can anyone confirm is the schematic for the e90 330d glow plug controller module the same as the e60,
Pins 1, 2, 3, 4, 7 and 8 are for glow plugs, 5, 6 and 12 are for can bus communication.?
White numbers are just 1-12 order, and red are connector pin numbers. Pins 1, 2, 3, 4, 7 and 8 are for glow plugs, 5, 6 and 12 are for can bus communication.
