wds
Old Jan 30, 2007 | 03:16 PM
radioham's Avatar
My Ride: 640D MSPORT GT
Thumbs up
has any one access to a wiring cct wds for the sept e60 2006/7
Old Feb 3, 2007 | 02:52 AM
radioham's Avatar
atention urgent,if you canhelp
Old Feb 7, 2007 | 09:06 PM
daMANiack's Avatar
My Ride: BMW E60 530i, Production Date May 2005
Hi,
I'm getting the latest WDS v10 within the next week, I'll check it out and get back to you.
What do you actually need, can you be more specific?
Cheerz
Old Feb 8, 2007 | 03:17 AM
radioham's Avatar
Originally Posted by daMANiack' post='388655' date='Feb 8 2007, 06:06 AM
Hi,
Cheerz
i actually need the print out of the a46 panel identifying the (contact-wiring pin on the plug for the trunk power outlrt)showing:
diagram -view of a46 trunk fuse/power module (changed in sept2006 from previous models)
1.picture of plug and pin numbers of connection point.
car is aug/sept 2006 535d rh/drive.
if you search for cigarette lighter in wds,it will come to block diagram view.showing; rear set lighters front lighter and trunk 12volt outlet,if you could print that into pdf file .then click on a46 area and then the connection [point in a46]where the 12volt outlet from trunk connects it will show you the plug assembly with pin number and location also colour of wires ,if you can save that as pdf .
thats what i need.just to get the correct position of wire connection.the a46 power distribution panel is changed now only has a very large multi 3 layer plug so if you can do that,it would be great help.
havnt been able to source a wds above 8 here in uk.
many thanks. jim
bmwfive
Oct 24, 2012 05:04 AM
AchtungE60
DIY: Do It Yourself
Jun 10, 2012 03:28 PM
DavidF
Apr 28, 2012 12:50 PM
response_surface
Feb 10, 2010 11:40 PM
bruce_miranda
Sep 1, 2008 11:23 AM
